The coolant thermostat? It's just three bolts, no need to remove the radiator or fan.
With the o2 issue, I seem to remember Jaycar having a kit to combat this very problem. Perhaps you could look into it?
I'm pulling the radiator out anyway to put the Mishi in, and switching to thermos.
I'll look into the Jaycar kit and see what I can come up with.
I'm seeking some guidance on what i should do to my stagea next. I have a hi flow turbo, and need/want both the dump and the FMIC. I can't afford both just yet, so can anyone recommend which would be more beneficial to go in first.
Cheers
Dump/exhaust. No question. FMIC looks shiny and nice but didn't notice much difference.
and you wont notice a difference with the FMIC. but when its 40+ degrees, your car wont be as bad as the stock FMIC, and you can also safely run more boost.
No PM yet... I just got back a spare actuator so I can send one over to Perth, that way you don't have the car off the road too long. I will need your original one back though, for the next person. :)
I had a thrash around Sandown today, happy to say the car ran very well. Still have to work on the cooling setup, even those massive 30 row coolers aren't up to the task. I may have to invest in some kind of water spaying setup for the front. 30 degree day at full noise saw everything shoot up. Oil hit 127 degrees, water 122 and the trans got to 105, all within 3 laps. :unsure:
At least the gearbox was ok. No limp mode, no slipping clutches. :)
Thats impressive Scotty. Thermos or clutch fan?
I've seen guys run water sprayers on intercoolers down here and seems to work a treat. Might be worth a go, and sounds like a cheap solution.
I got the Mishimoto radiator in today finally. Not a fun job. Even the new G35 radiator needs a lot of modding to make it fit.
Still need to connect the hoses and fill it up, and sort out the trans cooler. Not a job I'll be doing today, outside, in 39 degree heat.
Twin thermo's and the engine fan, all running constant.
Those Mishimoto radiators are a little difficult to fit, the top right mounting pin is slightly out, meaning you need to ditch the rubber part, and the condenser is hard up against it.
Rear mounted radiator?
Glad you had no failures; you could always drive slower... :whistling:
Edited by Daleo
Got home to see the wife vacuuming the dog hair out.
Training completed. :P
Well done....I'd believe she is a hard one to crack as well!
I had mine trained in 3 months.....she still don't vacuum though!
In a Christmas miracle, the car is back together, radiator in, Nismo thermostat in, Mishimoto silicon hoses in, B&M trans cooler in, bled (sort of), trans topped up, and ready to go.
That Mishi radiator is a bloody pain to fit. And bleeding these things? Scotty's cooling mod makes it easier but its still a bitch. Seems like the trick is to get the billet tap exactly upright the whole time you're bleeding.
Looking forward to driving for the first bit of tomorrow, and then giving it some hills spanking on the way up to Mannum for holidays!
What nismo thermostat did you fit. Is the one for the vq35 the same?
Yup. VQ35 is the same. Temps average at 77 now. Not sure if that's too cold but we'll see what happens when the thermos go in.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
