good luck with that its a fun job!!! try and get the O2 sensor off so you can get to the bolt behind it otherwise get a special ball joint cuppler for the socket not the yoke type cos it'll just bind up..........
ive got it booked into my mechanic so ill let him have the fun job. Was getting late so thought ...f#ck it. I see what people are saying. Bout not alot of room in there.
It's all about undoing the 4 bolts for the g'box crossmember & lowering that down to allow the engine to tilt back on the mounts. This gives enough room to get to the O2 sensor & top bolt/s. You may also want to drop off some of the shrouds further down the exhaust. This is why I raise the back of the car as well, otherwise ramps would be all you need. Your mechanic will have it done in no time on a hoist. But tell him to leave the bonnett up when he puts it on the hoist, just in case the engine hits.
Well, after stripping the bits i needed off an s2 at the local wreckers the car went in to have the manual conversion done.
Cant wait to drive it from the workshop to the exhaust place..... much excite
I vented my bonnet yesterday!
Seems to be doing the job......f#$k it lets(pumps) some heat out! When the thermo's come one I get that weird heat haze concentrated in one area. I'll post a pic of the top once I get the edging on.
Oh and purchased all new Nismo decal's! Just need Arec Tune to polish car now! :P
Which bonnet is that Craig? Getting copies made?
Lol, is that what you did?
Because race car.
my mates with evos have the same thing
DO NOT lean on the mesh! or you will end up with char-grilled patterns on your hand, though on evo's the vents are directly above the tubro
^^^ like!
Also like that it means your leg must be at the stage where your confident in driving a manual!
Yeah all progressing nicely, been driving now since July last year. Right knee is holding up, still gots a long ways to go tho. My PT is great as he's had a knee reco himself, so he knows the limitations when training.
Decided now that I got some extra cash and the time to take the car off the road to get some thing happening. Need to get new guages to monitor vitals, also check my ecu as to wether I can send it away for the nistune mod.
Picked up an m35 nm35 pnm35 oil sump pan from Nissan. Sorry just being obvious for the search function.
It's the bottom black thingo, so if you dent it, you can replace with
Part number 11110-AL810
I modified mine for an oil return, so when we took the turbo off, we placed with with a beaten out one until I could get a new one.
List price is $170 plus gst. Maybe a little cheaper.
Apparently lol
E-Troll alert!!!
Dale......yes it pumps the heat out......looks a lot neater with the edging now.
*****Cough*****reminder******cough******front******Reo!
Edited by Jetwreck
E-Troll alert!!!
Lol, fab starts tomorrow. ;)
Why did you put the hole there Craig? Is that really the hottest area? Or you just picked somewhere easy?
I was always hoping to get the Masa bonnet eventually...
http://www.rhdjapan.com/masa-motorsports-m-tune-frp-aero-bonnet-hood-56834
So I finally moved the stepper motor for the boost controller, cut almost half a metre out of the hose to the actuator, which was good. Others are *slightly* longer, so I'll test it tomorrow.
Because the back of my bonnet is already raised to get the air out. Also that is the area that most of the air get stuck in...I was finding the thermos could cool but because our bonnet is so low the air was still getting stuck in the front area. If a sidewinder is ever shot at my car now I know where it's heading. Those masa bonnets are nice but I cannot justify $1k ATM when I have other needs/wAnts.
I thought you proved that raising the rear of the bonnet did more harm than good, or Scott told me you did..
finished venting bonnet today......Wing and Front bar to go!
Great job but not entirely convinced it's in the correct area of the bonnet. I reckon positioned a bit more on the passenger side and higher would have it quite effective with heat extraction from the turbo area.
    • Look, realistically, those are some fairly chunky connectors and wires so it is a reasonably fair bet that that loom was involved in the redirection of the fuel pump and/or ECU/ignition power for the immobiliser. It's also fair to be that the new immobiliser is essentially the same thing as the old one, and so it probably needs the same stuff done to make it do what it has to do. Given that you are talking about a car that no-one else here is familiar with (I mean your exact car) and an alarm that I've never heard of before and so probably not many others are familiar with, and that some wire monkey has been messing with it out of our sight, it seems reasonable that the wire monkey should be fixing this.
    • Wheel alignment immediately. Not "when I get around to it". And further to what Duncan said - you cannot just put camber arms on and shorten them. You will introduce bump steer far in excess of what the car had with stock arms. You need adjustable tension arms and they need to be shortened also. The simplest approach is to shorten them the same % as the stock ones. This will not be correct or optimal, but it will be better than any other guess. The correct way to set the lengths of both arms is to use a properly built/set up bump steer gauge and trial and error the adjustments until you hit the camber you need and want and have minimum bump steer in the range of motion that the wheel is expected to travel. And what Duncan said about toe is also very true. And you cannot change the camber arm without also affecting toe. So when you have adjustable arms on the back of a Skyline, the car either needs to go to a talented wheel aligner (not your local tyre shop dropout), or you need to be able to do this stuff yourself at home. Guess which approach I have taken? I have built my own gear for camber, toe and bump steer measurement and I do all this on the flattest bit of concrete I have, with some shims under the tyres on one side to level the car.
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
    • I know I have to get a wheel alignment but until then I just need to bring the rear tyres in a bit they're wearing to the belt on the inside and brand new on the outside edge. I did shorten the arms a bit but got it wrong now after a few klms the Slip and VDC lights come on. I'd just like to get it to a point where I can drive for another week or two before getting an alignment. I've had to pay a lot of other stuff recently so doing it myself is my only option
