rear pads in, hopefully gotten rid of the wear issue i have been having, right hand pins/sliders were seized, so relubed that up and seems to be working better now. could actually slide by hand when i was done.
Got the HDI FMIC on yesterday, not too bad. I need to sort some broken/ missing/ torn out undertray bolts asap. I have the NUR catback exhaust and Scotty's dump and front pipe on it already. I think the next thing is Dales induction tube and a high flow turbo. But which one ? What I want is a quick road car not a race car I can nurse around the street, and the numbers are less important than the feel and driveability. But I'd love to try before I buy. :unsure:
I have the kits that Commsman uses to tweak the computer but haven't had a chance to solder them up. (Before anyone jumps on this I have been working overseas from 2/12/12 till yesterday.) (And I have not had the car tuned yet. :yucky: )
Hi Leigh. Give me a while & I may have a hi-flow you can try. But I wouldn't rush to change the standard turbo out, unless it's had it.
+1 with Leaon about the turbo.
If you do the Banjo mod and keep good oil in your car the stock turbo can perform very well and is hard to beat for off the line drivability.
OK Thanks for the offer Leon and all the great help, assistance and advice you have given me so far. I love my sound system/media system. The cruise is absolutely necessary and even the wheel switches started lighting up since we did the slimline fan in the FMIC install! Go figure! :wacko: As it gets quicker it gets harder to set the cruise to avoid it hunting but that's expected at some level as the turbo spools. Just went down town through a 50 zone and watched the car burble up a rise at 900 rpm/50 kph in top gear! Gotta love that... When I said that I wanted to try before I buy ... I meant experience what other turbos respond like, not necessarily from a drivers seat. A seat of pants from a back seat where I can see the rpm, roadspeed and feel the response should give me a clear idea if it is too laggy for my taste. This car will never be raced, if it does go down a drag strip that will be the exception rather than the rule. The problem is trying to find the balance between driveability and power. As I do not want an extreme car some of the more prominent peoples experience is irrelevant. It is probably true that the people I really want to connect to do not post overly much. So if you are out there and have a moderate highflow and induction solution with great driveability and reasonable performance at a realistic price please respond! My standard turbo is OK atm so I am not under any pressure at this time. :closedeyes:
i'm pretty sure someone is rebuilding the turbo basically to stock spec's might have to ask Jet_Wreck about it.........
hi Andy long time no speak, what's the banjo mod?
That's where you drill out the turbo oil feed line at the banjo bolt. It is a really small hole that can get blocked by grunge, especially if service intervals were 'stretched' when back in the mother land.
It is widely believed that Aaron's turbo failed due to this oil line being blocked.
Looks like he thinks Craig's advice is irrelevant, it's the reason I never posted a response anyway.
cheers Leon. :)
Replaced my broken cibie light glass.
Cleaned up ok Josh?
Looks like he wants something he can drop in without tuning etc, and doesn't want the power some guys are making. I get that.
I don't think Craigs' recent thoughts are common knowledge, ie he wouldn't know if irrelevant or not. And, as it turns out, is very relevant.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
