What?
C'mon Scotty, you're only guessing that is the cause :no: . Pretty sure Ryan proved otherwise by disconnecting/reconnecting cruise control. Appears to only be an issue with (some) people running F-Con & given all the wiring changes involved with F-Con installation......
No one else with cruise control has reported TPS codes & most have had it working for over 12 months (mine over 18 months). Probably a combined error free distance of over 150,000km.
Unfortunately I have had no errors since unplugging the cruise, I would say too many things hanging off the pedal output wires will cause it to fault.
Maybe the cruise was the straw that broke the camels' back, so to speak :)
I still want to try a new pedal sensor, but at $300-$400 for a varistor I will just unplug the cruise for now. Sadly, I don't think the fcon even uses the pedal sensor as an input now I think about it. It could be a bad connection in the cruise wiring too I guess. I really want to fix it as the cruise function is great...
Limp mode is a pain, I am scared it will happen with the family in the car while trying to scoot across an intersection. It faulted 8 times on one trip just dropping the kids at school last week. Goddamn electronic throttles.
Has anyone had a fault code P1320 ignition signal come up before on there M35?. Am I due for new coil packs? Or is it to do with plugs. Any ideas would be great.
It is indicating a fault with the ignition circuit, probably best if you start a new thread on it so others can find this same info.
It is letting you know there is a slight resistance change somewhere inside a coil primary or ignition harness. Have you been poking around with the coils recently, or changing plugs? If not it sounds like you will be soon. :P
Mine threw this code when I had the Emanage Ultimate wired in.
Thanks Scotty. I haven't opened the bonnet for 4 weeks. My wife rang and said the engine light wont go off. Looks like a fun job to change coil packs. The code has cleared for now. Hope I dont see it back too soon.
On the subject of coil packs...
I changed my cam cover gaskets on Friday because they were both leaking & at the same time took the opportunity to change the spark plugs.
I dont think they'd been changed in quite a few years - both electrodes were worn away pretty badly - so badly infact that the gap was close to 3mm!
Demonstrates how strong the spark is from the coilpacks if it could keep the car running fine regardless.
Although I must say there's now a very noticable difference in engine response now that the new 1.1mm plugs are in. :O
* And christ, what an ars$ehole of a job that passenger cam cover is to get back on without the rear part of the gasket falling back out - that aircon line can f**k right off.
I need to do my plugs to but have been putting it off.
Also it was me who messaged you. Not some random lunatic... well maybe
NGK Iridium LFR7AIX. I get them from ebay mate. Or you could get them from Harold (Performancelub). Still perfect after 20,000 k's on my car.
Don't get the IKH22's, a few sets I have noticed the threads galling in the head, probably due to them being stainless, and the tip melts within 20,000 (on a stock Stagea). Perhaps the IKH24's might be better, with some anti-seize paste? Or just run the NGK's like me. :)
Just telling it how it is mate. Not telling you to change, just letting everyone know my experiences, it's not like there is a price difference. Perhaps you drive like a pussy compared to Jase? :P
lol.
That said, I put the Denso's in because I had them already. Next set of plugs will be neither NGK nor Denso. There are more interesting designs out there that I want to try :)
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
