Well thanks for jet r31 getting me off my butt and giving me a hand, I've nearly finished hooking up my water/meth injection, then it's tune time again see what happens :) cheers brother . Also I fitted up my rear brake conversion and front adjustable camber and radius rod arms and chucked in a set of new tie rod ends and a afr gauge to go with the rest of the info in my cockpit
Ready for the cruise? Or you taking the daily?
Had my drivers side front wheel bearing replaced this morning; nice & quiet again.
Not doing it myself was the best $160 I've spent this week.
God I'm lazy. :woot:
Edited by Daleo
  • Like 1
You are lazy! Easy job is easy!
Just got back from the retune.
Car now runs on the MAP sensor. MUCH MUCH MUCH more responsive, but no more power. Apparently 200kW on a Dyno Dynamics now, but no print out.
The weird thing is it's running Scotty's modded actuator and only running 9psi at the top - so it's 2psi more than last time with the stock actuator.
Got to get this boost sorted, and find out why it seems to be speed limiting still.
Much better package though, and much happier. Just want my farkin boosts!
9psi? it sounds like you have a leak in the vac line, or yours is the only turbo not holding boost.
Did your turbo have a larger wastegate puck or something?
Perhaps the actuator doesn't have enough preload?
Check this. You need about 3mm of the width of the hole on the actuator for preload imo.
Bigkev ,no print out I would be asking "demanding a print out " it's an important reference to your car it's no good having all the bells and whistles and not having a guide to what it's doing and be a grumpy man if I was you
^ This. Just what the hell are they doing Ryan? You'd think for a shop with such a reputable name, they'd be a bit more helpful... or is it because you don't have an R35?
I think he's had someone else look at it..? or run it elsewhere. Dunno who has an AWD Dyno Dynamics unit off the top of my head!
Ryan, check out Theo's boost drop. He's stock turbo too, I suspect it's all about running out of compressor flow.
http://www.skylinesaustralia.com/forums/topic/357886-lambchop-with-a-renault-axis-here/?p=6493662
When I had my stock turbo it would hold at least 13psi to redline. No doubt it does run out of flow, but 9psi sounds too low.
How is boost control being done Ryan?
Thanks guys. I'll try and tick everything off...
I've replaced every vac line now I think. I can't see how that would be it.
Stock turbo, stock wastegate puck. Andrew at AM wants to bore out the wastegate 1mm but nothing has been done yet.
Actuator is your modified one, exactly how you sent it to me. If it needs more preload do I just put a stronger spring on?
Which hole Craig?
Thanks guys. No printout, it was supposed to just be a fix session and the map ended up being redone. I could have asked for the printout. I didn't. I'd just sat in the passenger seat and seen the whole thing so didn't think to ask.
Mine was similar to that (although wtf is that at the end of the drop off?!). I wouldn't have thought it was running out of compressor flow that early? I thought others had more success on the stock turbo. Funny that Theo and I have both changed the vac hoses, and both get similar graphs.
Scotty's modded actuator with the HKS EVC.
9psi is the boost I used to get when my boost solenoid would stick open. Sounds like the wastgate is fully opening.
Weird thing is, it was 7psi without the modded actuator, 9psi with.
I want to see if I can find the boost problem, fix it, then take it to somewhere else to get the EVC setup properly and the tune checked.
For the record, the original tuner (who I won't name on here but some people know) once I explained all the issues offered to fix it, ended up retuning on MAP instead of AFM at my request, and spent near enough to two hours with me explaining things and talking about it. So far it seems like they have fixed it and improved it no end, but at the request of a few people I'll get it checked out just for peace of mind.
My actuator has almost 5mm of preload, the stroke of the thing is huge.
The hole Craig is talking about is the hole in the Wastegate arm, that the pivot pin goes through.
Boring out the Wastegate isn't going to make it hold boost better, if anything; it will allow you to bleed boost pressure more easily.
It would be worth doing if you were building boost pressure uncontrollably, but you have the exact opposite issue.
What's stock? From memory 3mm isn't it? And I didn't think Scotty modified that hole. Should I drill it out to 5mm?
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
