Had noble intentions today of fitting up the LSD rear end & the Scotty dump, front pipe & new Blitz Nür catback I got the other day...
Diff went in fine, but I was foiled utterly by the stock dump pipe... :(
I even called Scott to walk me through it, but couldn't for the life of me remove the O2 sensor with the tools I had - and as a result I couldn't get to the top centre nut to the dump pipe flange.
Fitted up the rest of the exhaust to the stock dump (will be forced to ask Craig to do it for me while I hang my head in shame) and I'm glad to report that its SUPER quiet. At idle, it's not much louder than the standard exhaust & probably just as loud as the induction roar on WOT.
Will be interesting to see if there's any change in noise levels once the factory dump/cat is swapped for the good one...
I'll be at the workshop bright and early tomorrow if you want to head down. Give me a buzz or SMS on 0406754304.
finally ive been waiting to post this. :yes:
cars tuned, very happy with the results its been a long time( almost 3 months) with issue and constantly annoying the guys on here.. but first in WA :)
it is road tuned so no dyno results as yet guys but its a big improvement and im sitting at 19.5psi :)
id really like to thank Scotty, Craig, Ryan and of course all the others for imput for helping me through the tuning/ mehanical issues ive had. :cheers::cheers::cheers:
i will get dyno run for all you doubters eventually lol
Nice work Chris.
What was the boost issue in the end?
No fault codes I take it?
Got the audio controls on my steering wheel working with my head unit. Just 2 wires to connect together & another one to ground then store the functions in the memory. No fancy conversion box required in my case.
It sounds so simple when I read this back, lol. There were lots of hours of searching, reading, prodding & measuring to get to the point of 5 minutes of soldering & crimping. Been meaning to do this for 18+ months - thanks Rich (richzx) for the motivation to get off my bum & do it :cheers: .
Had super happy family time today and couldn't sneak away. Do you work nights, Dr Craig? :O
Edited by Mr 20Valve
Finally got around to fitting a full radius bell-mouth in the factory air-box. Happy with the fit and yet to see if the Airflow properties have improved performance. its certainly better than the crude OEM bellmouth IMO.
Nice Benny. Will be good to hear how it reacts to that.
You'll enjoy that mate!
Any work on the suction/intake side to aid flow?
Thats one of the next things to sort. Just looking into options. I need it before I get an emanage etc.
But so far mod list is
Sierra stage one turbo
Nismo ecu
Scotty dump
Scotty front pipe
Nismo exhaust
HDI front mount will go on this week
Looks like I have a plenum spacer lined up
Just ordered a shift kit
Also have scottys coolant mod sittting there to go in.
What do people think is the best suction pipe?
Mine works quite well. It would be fine for that turbo. Also skirts the AFM cut issue.
Is relatively cheap and made on a jig as a direct replacement for the OEM restrictive cast nugget.
Completely invisible once fitted. I have several of these in service and performing well.
Scotty makes an excellent one, and is proven at huge power levels.
AM Performance in Radelaide do a very neat replacement; Ryan (Bigkevracer) can vouch for it.
Edited by Daleo
Yeah I was going to ask you about yours. What do youcharge for yours? What numbers have people pulled with your pipe?
I have been looking at the AM one but not completely. Sold on it yet.
Scottys is a possibility. But he does require the car which is not out of the question but would be better not having to drive to mexico
PM coming your way.
What have I been doing to my stag lately,
Well I put on R33 front & rear calipers with
brand new dba slotter rotor and project mu pads.
Brakes feel really good now
And just last night I put in a recaro bucket seat
With a bride super low seat rail only bad thing is
I can't see over the bonnet now :-(
Hey Josh can you be a bit more specific with the difference the intake made? I want one but don't want the AFM cut out issue or maxing the injectors. You have the standard turbo as well?
Hey Dale can you pm me the price on yur intake please?
Here's a couple of rubbish pics of my car with the new wheels on 19*9.5 + 35 with 245/40/19 tyres. The handling is much improved.
I can't get the caps on because of the hub nut things but I think it looks good without the caps anyway.
I can't stop staring at the entrance way appearing like it's sinking into middle earth.
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
    • I know I have to get a wheel alignment but until then I just need to bring the rear tyres in a bit they're wearing to the belt on the inside and brand new on the outside edge. I did shorten the arms a bit but got it wrong now after a few klms the Slip and VDC lights come on. I'd just like to get it to a point where I can drive for another week or two before getting an alignment. I've had to pay a lot of other stuff recently so doing it myself is my only option
    • You just need a wheel alignment after, so just set them to the same as current and drive to the shop. As there are 2 upper links it may also be worth adding adjustable upper front links at the same time; these reduce bump steer when you move the camber (note that setting those correctly takes a lot longer as you have to recheck the camber at each length of the toe arm, through a range of movement, so you could just ignore that unless the handling becomes unpredictable)
    • I got adjustable after market rear camber arm to replace the stock one's because got sick of having to buy new rear tyres every few months. Can anyone please let me know what the best adjustment length would be. I don't have the old ones anymore to get measurements. I'm guessing the stock measurement minus a few mm would do it. Please any help on replacing them would be fantastic I've watched the YouTube clips but no-one talks about how long to set the camber arm to.
