I have a few but none fit down (or up) there properly. I can do it in a minute or two now with my cut down 22mm open end spanner though.
I fitted Whiteline diff bushes in my car today, quite cheap to buy too. It made one hell of a difference too, all the axle tramp is gone and it chirps nicely between gears again, it really tightened the whole back end. My original rear diff bush was totally flogged and was leaking oil.
well on the bright side it will be a good test of banjo sizing.
symptom 1 of too much oil to the turbo will be burning oil at full boost (grey/white smoke)
symptom 2 of too much oil to the turbo is the turbo seal blowing.
If neither of those happen, it's not too large :)
  • Like 1
The stock Garrett core will have a restrictor built in so it shouldn't pose too much risk, that said the VQ runs stupidly high oil pressure, I have seen 10 bar on my gauge which I think is it's limit...
I wonder if that had something to do with my issue? Stao told me to drill mine to 4mm.
That seems very large. I did mine with 3mm (think that is what is was, was more like find drill bit to drill after 10 hours under the car changing turbo).
I agree with scott, 2.5mm max.
John from Precision recommended I drill mine to 4mm; so I did. No issues with mine.
Oh joy. Replaced another AFM.
FML.
I popped my new genuine Nissan one after about a month; failed just as the car started.
I bought a WRX one the 2nd time. It seems to be going fine.
It fits about 4 billion different models, so at least they're easy to get.
What number are you on now? I think I've killed 3 now.
Did you buy new last time, should be under warranty surely.
This is the 2nd one thats died in 4 months.
Got a 2nd hand one last time from a wreckers which they gave me 3 months warranty on - failed after 4 months to the day. lol
Today Craig and I, well lets be honest mostly just Craig fitted the plenum spacer, scotty's coolant mod, transgo shift kit and finally got around to doing the fun switch mod.
Improvements?
Shifting is definitely faster and I actually think smoother. I havent driven it alot yet but we stalled it up and even with the fun switch off the boost is coming on much stronger. Will see how it goes after I drive it a bit. Still have a random stalling issue but hopefully will get that sorted soon. The car is getting there :)
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
    • Final update!!! Got the front bar fitted and sprayed and all sorted now. My cutouts worked great and the indicators aren’t just falling off. 😂
    • Is this a brand new LSD? if so, have you followed any break/bed in procedure for it? Usually involves heaps of figure 8 patterns, a fluid flush.
