Thought the turbo had shit itself tonight on the drive home.
Ends up it was the wheel bearing, coincidentally one day after dad was in the car and thought he heard a noise from the front right.
So calls start tomorrow to locate one. Is everyone sourcing from Nissan or Amayama? Anyone trying a bearing specialist like CBC?
Part number is on Just Jap so all good there.
Yeh I popped one 2 days ago....might have been going for a while though!
Just Jap sell them about $50 cheaper than Nissan :O
The engine's in and is coming together very nicely, just waiting on the map sensor which could be here tomorrow and it's all done, here's some of Scotty's handy work. tn_gallery_79015_4374_861241.jpgtn_gallery_79015_4374_575164.jpg
Edited by gleeson
My thoughs exactly. With the mat black wouldnt even know its there unless the bonnet was up but even the its hardly noticeable. With that and my varex the stagea wont be bothered by the pork sandwich patrol...
