So Bilstein's and Nismo's IN!
Most of you can probably see the error. If it wasn't for that error I would have had the shocks and springs in about 4 hours with hand tools, without counting the separate days I did to compress the old springs out of the Bilsteins. But all up 7 hours :(.
Fixed. Lucky I sent a pic to Jetwreck. :worship:
Edited by M35woah
All good mate; it's not a race to see who works the fastest, I'd rather see a job done RIGHT than a job done fast and WRONG.
I've been telling apprentices this for years.
Good to see you had a go yourself. How does it ride now?
Welcome to the nismo/bilstien club!!
They got better when they settled in I thought, I've had mine second hand from Craig for about a year now and still happy with them.. The rear springs where sqweaking but wd40 fixed that ;)
Yeeeessssss......yesssss you do! Bad mistake by me!
Picked this up today! $30 for Gold Coast, hopefully have it installed tomorrow
Why don't you get it ceramic coated before installation, to stop it degrading any further?
Mmm where / who in sunny coast would do that? And what's that normally cost?
I'm not sure about Sunny coast, but check locally for companies doing performance coatings.
Id expect it to be in the $200-$300 mark for a heat insulating black ceramic. The chrome finishes are more expensive, because of the extra steps in producing the shiny finish.
It's a none oiled filter! Same one I ran in my vl, it's actually the same filter as a vl. Rang a shop that does ceramic coating! Gonna to see them, $150 to $200 but he doesn't know If he can have it done by next week! Wheel alignment has made a huge difference! Actually have to put the brakes on at lights to stop it rolling
You're smashing through the jobs on this poohkies!
I'd definitely recommend getting it done; once coated it'll last bloody ages longer than just raw galvanised.
I might have to get the thermal gun out & do some comparative temp measurements on my coated components versus non-coated components.
  • Like 1
Or alternatively...... you could spend a few minutes making up another front chassis brace.
Just sayin' :P
  • Like 2
Just sayin' :P
Point taken Leon, I'll have yours in etch primer ready to send out on Monday. :rolleyes:
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
    • Final update!!! Got the front bar fitted and sprayed and all sorted now. My cutouts worked great and the indicators aren’t just falling off. 😂
