Okies so on the hunt for a boost gauge in the sunny coast Brisbane area before drags on Wednesday! Also modded the airbox and pulled out the corner cap so it can suck in more air!
i am intrigued by your ideas & would like to subscribe to your newsletter...
NP, will email you next issue.
Just be careful he doesn't involve you in his product test procedure.
I tested this procedure on my own car (remember the dump truck rolled into me at road works) & my working boot mech continued to work afterwards, so I'm 90% sure my DIY is accurate. However I am looking for a few volunteers to try it, just to rule out any abnomalies.
Is the hdi any good?
I've never really heard anything exceptional about them. They aren't adjustable for ramp rate or duty cycle are they?
i have one in my 260rs and have never had a problem
Personally I like it. Do have the odd boost fluctuation within 0.8 psi I have found. Have dual stage settings with push button selection. Bought it due to my issues with stock boost solanoid that was playing up and this fixed it.
Got a tune yesterday from one of NZ's top tuners (def the top Nissan tuner) - will post the results when I get a chance to scan the charts - but learned two interesting things:
1. I have (along with a lot of other people) been using and recommending BCPR6 or 7 spark plugs but they are WRONG! I found my last tuner had gapped them down to 0.5mm to try to eliminate misfiring at high revs and boost (7000 @ 1.4 bar). Soichi said I should use PFR7 to fix this problem. If you check the NGK application guide you will find they list BCPR5 for the RB25DE and for the RB25DET they list PFR5G. So I will be getting some PFR7s!!
2. Don't use E10 fuel (in NZ anyway) - it seems the only distributor in NZ ...Gull... say they use "up to" 10% ethanol so for highly tuned engines it is too unstable.
I was under the impression that platinum plugs didn't fair too well with tuner vehicles and tend to not last as long as the equivalent copper.
No direct experience, only reading. I have both in two different cars.
WTF?
LOL!
And by that I mean technical data, not "my car runs awesome on.....xxxx"
What kind of data would impress you? My car ran awesome on BCPR7ES but the previous tuner showed me on the screen of his dyno the misfiring at high revs and boost but apart from gapping down the plugs he didn't suggest a solution.
The tuner I went to on Thursday was Soichi from ST Hytech and if he is not the best Nissan tuner in the country then he certainly is extremely experienced having tuned many of the top GTRs in this country as well as some in South Africa and a few other places - including street cars, drag cars and circuit racers so he has seen the proof on his dyno as well as on the 1/4mile etc. That's good enough for me. I am sure other tuners can get good results with different plugs and ignition systems - that's cars for you.
I don't want to be impressed. I just want something more interesting than "my car runs awesome on...". I'm not doubting your tuner, if you say he is knowledgable, I have not reason to question it. However, ngk themselves say that you effectively throw out the reference table when it comes to modified engines.
I know you have 100k km service intervals for platinum plugs on stock engines, so obviously the longevity is there in tested conditions. However, my thoughs is that when your running something a fair bit more strenuous than stock, the comparatively thin precious metal coating may well disintegrate quickly compared to a thicker copper item. Especially so if your heat range isn't quite right. Then there is the price difference.... $4 to $20-30ea....
The only set of copper plugs I have ever found for the VQ were $14 a plug, same price I pay for Iridiums which last much longer. I could probably go well over 50,000ks on a set of LFR7's if I chose to, but Cihan likes me to change them regularly. If I want 8's the price goes up to $300 a set. (Nismo plugs) If I could get coppers for $4 I would probably be using them, because tight arse.
Currently running 30psi on stock coils without issue. (on e85) Tractor motors have different requirements obviously. ;)
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four-speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to its full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so stupid hot in there, that made it all the more easy -after I was standing there looking at the car and said 'f**k it'- to finally remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
    • Thanks for that, hadn’t used my brain enough to think about that.
    • Also playing with fire if they start to flow more air down low than what the stock twins can. It's not even up top you need to worry, it can be at 3000rpm and part throttle and it's getting way more flow than it should.
    • Any G40/1000 or G40/1250 results out there?
    • You still want a proper tune on the stock ECU though. Stock tune + stock ECU with GT-SS/-9s is probably playing with fire if you're running more than stock airflow/power.
