Okies so on the hunt for a boost gauge in the sunny coast Brisbane area before drags on Wednesday! Also modded the airbox and pulled out the corner cap so it can suck in more air!
i am intrigued by your ideas & would like to subscribe to your newsletter...
NP, will email you next issue.
Just be careful he doesn't involve you in his product test procedure.
I tested this procedure on my own car (remember the dump truck rolled into me at road works) & my working boot mech continued to work afterwards, so I'm 90% sure my DIY is accurate. However I am looking for a few volunteers to try it, just to rule out any abnomalies.
Is the hdi any good?
I've never really heard anything exceptional about them. They aren't adjustable for ramp rate or duty cycle are they?
i have one in my 260rs and have never had a problem
Personally I like it. Do have the odd boost fluctuation within 0.8 psi I have found. Have dual stage settings with push button selection. Bought it due to my issues with stock boost solanoid that was playing up and this fixed it.
Got a tune yesterday from one of NZ's top tuners (def the top Nissan tuner) - will post the results when I get a chance to scan the charts - but learned two interesting things:
1. I have (along with a lot of other people) been using and recommending BCPR6 or 7 spark plugs but they are WRONG! I found my last tuner had gapped them down to 0.5mm to try to eliminate misfiring at high revs and boost (7000 @ 1.4 bar). Soichi said I should use PFR7 to fix this problem. If you check the NGK application guide you will find they list BCPR5 for the RB25DE and for the RB25DET they list PFR5G. So I will be getting some PFR7s!!
2. Don't use E10 fuel (in NZ anyway) - it seems the only distributor in NZ ...Gull... say they use "up to" 10% ethanol so for highly tuned engines it is too unstable.
I was under the impression that platinum plugs didn't fair too well with tuner vehicles and tend to not last as long as the equivalent copper.
No direct experience, only reading. I have both in two different cars.
WTF?
LOL!
And by that I mean technical data, not "my car runs awesome on.....xxxx"
What kind of data would impress you? My car ran awesome on BCPR7ES but the previous tuner showed me on the screen of his dyno the misfiring at high revs and boost but apart from gapping down the plugs he didn't suggest a solution.
The tuner I went to on Thursday was Soichi from ST Hytech and if he is not the best Nissan tuner in the country then he certainly is extremely experienced having tuned many of the top GTRs in this country as well as some in South Africa and a few other places - including street cars, drag cars and circuit racers so he has seen the proof on his dyno as well as on the 1/4mile etc. That's good enough for me. I am sure other tuners can get good results with different plugs and ignition systems - that's cars for you.
I don't want to be impressed. I just want something more interesting than "my car runs awesome on...". I'm not doubting your tuner, if you say he is knowledgable, I have not reason to question it. However, ngk themselves say that you effectively throw out the reference table when it comes to modified engines.
I know you have 100k km service intervals for platinum plugs on stock engines, so obviously the longevity is there in tested conditions. However, my thoughs is that when your running something a fair bit more strenuous than stock, the comparatively thin precious metal coating may well disintegrate quickly compared to a thicker copper item. Especially so if your heat range isn't quite right. Then there is the price difference.... $4 to $20-30ea....
The only set of copper plugs I have ever found for the VQ were $14 a plug, same price I pay for Iridiums which last much longer. I could probably go well over 50,000ks on a set of LFR7's if I chose to, but Cihan likes me to change them regularly. If I want 8's the price goes up to $300 a set. (Nismo plugs) If I could get coppers for $4 I would probably be using them, because tight arse.
Currently running 30psi on stock coils without issue. (on e85) Tractor motors have different requirements obviously. ;)
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
    • When I said "wiring diagram", I meant the car's wiring diagram. You need to understand how and when 12V appears on certain wires/terminals, when 0V is allowed to appear on certain wires/terminals (which is the difference between supply side switching, and earth side switching), for the way that the car is supposed to work without the immobiliser. Then you start looking for those voltages in the appropriate places at the appropriate times (ie, relay terminals, ECU terminals, fuel pump terminals, at different ignition switch positions, and at times such as "immediately after switching to ON" and "say, 5-10s after switching to ON". You will find that you are not getting what you need when and where you need it, and because you understand what you need and when, from working through the wiring diagram, you can then likely work out why you're not getting it. And that will lead you to the mess that has been made of the associated wires around the immobiliser. But seriously, there is no way that we will be able to find or lead you to the fault from here. You will have to do it at the car, because it will be something f**ked up, and there are a near infinite number of ways for it to be f**ked up. The wiring diagram will give you wire colours and pin numbers and so you can do continuity testing and voltage/time probing and start to work out what is right and what is wrong. I can only close my eyes and imagine a rat's nest of wiring under the dash. You can actually see and touch it.
    • So I found this: https://www.efihardware.com/temperature-sensor-voltage-calculator I didn't know what the pullup resistor is. So I thought if I used my table of known values I could estimate it by putting a value into the pullup resistor, and this should line up with the voltages I had measured. Eventually I got this table out of it by using 210ohms as the pullup resistor. 180C 0.232V - Predicted 175C 0.254V - Predicted 170C 0.278V - Predicted 165C 0.305V - Predicted 160C 0.336V - Predicted 155C 0.369V - Predicted 150C 0.407V - Predicted 145C 0.448V - Predicted 140C 0.494V - Predicted 135C 0.545V - Predicted 130C 0.603V - Predicted 125C 0.668V - Predicted 120C 0.740V - Predicted 115C 0.817V - Predicted 110C 0.914V - Predicted 105C 1.023V - Predicted 100C 1.15V 90C 1.42V - Predicted 85C 1.59V 80C 1.74V 75C 1.94V 70C 2.10V 65C 2.33V 60C 2.56V 58C 2.68V 57C 2.70V 56C 2.74V 55C 2.78V 54C 2.80V 50C 2.98V 49C 3.06V 47C 3.18V 45C 3.23V 43C 3.36V 40C 3.51V 37C 3.67V 35C 3.75V 30C 4.00V As before, the formula in HPTuners is here: https://www.hptuners.com/documentation/files/VCM-Scanner/Content/vcm_scanner/defining_a_transform.htm?Highlight=defining a transform Specifically: In my case I used 50C and 150C, given the sensor is supposedly for that. Input 1 = 2.98V Output 1 = 50C Input 2 = 0.407V Output 2 = 150C (0.407-2.98) / (150-50) -2.573/100 = -0.02573 2.98/-0.02573 + 47.045 = 50 So the corresponding formula should be: (Input / -0.02573) + 47.045 = Output.   If someone can confirm my math it'd be great. Supposedly you can pick any two pairs of the data to make this formula.
    • Well this shows me the fuel pump relay is inside the base of the drivers A Pillar, and goes into the main power wire, and it connects to the ignition. The alarm is.... in the base of the drivers A Pillar. The issue is that I'm not getting 12v to the pump at ignition which tells me that relay isn't being triggered. AVS told me the immobiliser should be open until the ignition is active. So once ignition is active, the immobiliser relay should be telling that fuel pump relay to close which completes the circuit. But I'm not getting voltage at the relay in the rear triggered by the ECU, which leaves me back at the same assumption that that relay was never connected into the immobiliser. This is what I'm trying to verify, that my assumption is the most likely scenario and I'll go back to the alarm tech yet again that he needs to fix his work.      Here is the alarms wiring diagram, so my assumption is IM3A, IM3B, or both, aren't connected or improper. But this is all sealed up, with black wiring, and loomed
