S1 Dayz.
Pic of the freshly painted brakes, because I just worked out that I can attach files using an iPad (yeah, yeah: I'm a slow adopter...)
Still have to tidy up around the engine bay: that wiring is embarassing... but you get the idea.post-39451-0-64102700-1377560237_thumb.jpgpost-39451-0-92587600-1377560277_thumb.jpg
Just received my Synx 6000, LS90 (diff oil) and bought some semi-syn gearbox oil the other day
Time for some loving for the stag
Oh, and polished the bonnet and roof the other day
My qutar window vents [what i guess you call them] started to flake so i decided rather then risk breaking them by pulling them of to respray i would cheat and plasti dip them insted [also alot cheaper seeing as i had left over and easier]
 *snip*
Hahaha every time i come into this thread i see one of my next mods all listed out.
I was going to do this exact same thing; also on silver stag...
:lol:
Hahaha every time i come into this thread i see one of my next mods all listed out.I was going to do this exact same thing; also on silver stag...:lol:
Twins...lol
  • Like 1
I think 13kms out of a rebuild is a good enough reason to look for a different engine builder. id expect a free rebuild on the 2nd one for that effort.
6th booking part one: never actually made it onto the dyno due to bottom end knock: engine had spun a bearing 13km after rebuild
S1 Dayz.
Still have to tidy up around the engine bay: that wiring is embarassing... but you get the idea.attachicon.gifimage.jpgattachicon.gifimage.jpg
I have been trying to figure out how to do this but can't get anywhere ( attach photos ) how did you do it.
...And that's exactly how it panned out...
Have to use the full site, then go to "more reply options", and you can attach from camera roll.
no idea if it works from iphone: too pokey, so I cbf trying.
Synx 6000 in - happy days
2+ hours rolling around the floor only to undo one fill plug for the rear diff - sad panda
who decided to make gearboxes and diffs so shit to put oil into?!?!
I think i'll pay someone to do this job
oh, and one of my headlights is out :(
fingers crossed it just the bulb
anyone have the link to the place selling the philips bulbs for a reasonable price?
On my M35, it's easy :w00t:
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
    • Final update!!! Got the front bar fitted and sprayed and all sorted now. My cutouts worked great and the indicators aren’t just falling off. 😂
    • Is this a brand new LSD? if so, have you followed any break/bed in procedure for it? Usually involves heaps of figure 8 patterns, a fluid flush.
    • It's TWO steering wheels actually. 😛 one for each hand They are wheels, and they steer!
