Two blokes, workin 9-5:30pm doing a full paint correction. APC, foam lanced, ironX, clay bar, polished for 4 hrs with ROs, sealant, wax. Knackered.
Not leaving the garage with it before the stagea cruise!
Who did it Alex?
A workmate of mine.
He does a bit on the side for some cash. Very professional and very OCD. Would recommend. However if it catches the nail, it isn't coming out, so if your thinking those key marks, they could be reduced I guess, but not removed.
He's in the bexley area. Have a look at his handy work on Sunday :)
A workmate of mine.
Nah, I'm not worried about the key marks right now; no amount of buffing will get clear back on the exposed black base. The damaged panels will have to be sprayed which is on the list currently. I hate vandals...
Looking forward to seeing the results mate!
Took my car to barbagello, first time on a proper track to open her up. On the last run got my courage up and pushed it harded and passed a s13 easy and reeled in on a 345hp chaser. Hit speed cut on the back straight :( and got plenty of fade from the brembos !!
Next up is install sld dyno and dyno run..
Very happy with the car atm!!
Took mine got its first proper drive since the build: absolutely fantastic! Only downer was the plague of Lycra lovers, and the rubber messing up my front and rear guards ;) .
Almost crossbreed it with a Toyota 86 today when some complete muppet in a white Toyota 86 decided to speed up and try to turn right from the left lane of the roundabout I was going straight through. Really clever: was within 2 inches of having his car as a bonnet ornament...
very nice suction pipe!
P.S. Without the fan shroud I suggest you do some shielding in front of the pod to get rid of the hot air.....remember the heat sensor is in our AFM and it will affect your power through traffic.
  • Like 1
Qfm hpx. I think my next upgrade is slotted rotors maybe some better street pads and some new fluid :)
Remsa or ar1m might help you out, hpx are pretty tame
A1RM's still fade. Better off keeping the HPX for road duty and running some race pads for the track.
I got project mu track pads with the brembos but didnt put them on obviously.
Whats the view on skimming the rotor if i change from the track to street pad and vice versa?
Replaced shocks all round, and bled the callipers since i was there.
Also - HPX are hopeless for track work. I know two people who tried tand both were miserable failures.... A1RMs are a whole different story, but i would expect they would be tough on rotors if you used them for street. Cold bite is not great either, so agree that pads are the #1 thing to swap in and out for track days (or maybe #2 after tyres).
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
