I got the HKS Silent Hi-Power exhaust fitted today at Hills Motorsports. Probably a good thing I paid to get it put in as some bolts were quite stuck, to be expected on a 16 year old factory exhaust.
Sounds great around about 3-4000 RPM, very quiet on idle compared to the factory system.
Finally reunited with mine last Tuesday after 2 months off the road.
Now sporting a rebuilt transmission from Kewish. Never realised how much I enjoyed my until I had to drive a 2" raised Prado for a couple of months (good car, but that handling :()
What happened to box?
Hit a 'roo.
Impact caused leak in lines which I couldn't see, being just after 1am.
Got home, no fluid in box.
Much better now though.
Downside is that it also tore apart the harness leading to the EGR sensors.
Wiring was worked on but still get engine light so may need a replacement harness... too bad it is the same harness that runs along the top of the engine :(
Edited by iamhe77
  • Like 1
S So after a few years of purchasing the bmc g35 cover I have finally made the effore of making securing brackets. All thats left to do is paint them black and source some black pop rivits to finish it off.
Edited by joshm35
Lakes101 awesome work mate!!!!
Love the strut brace? where can I get one from for the Axis?
Love the catch can mounting, interesting location thats for sure.
Regarding the cooler install, how much of the reo bar did you have to chop out and mod?
  • Like 1
There is no chopping or modding required with the Hdi front mount.
Hi Guys!
I thought you might be interested to see what I've been doing to my Stagea in the UK. I know Stageas are big in Oz but we have quite a good scene here and I'm aiming to build one of the best:
Here she is, just back from the bodyshop:
That's 19x12" rears with 355 tyres BTW!
  • Like 2
cheers mate. The strut brace is a g35 one from the U.S. Can't remember where I got it from most likely conceptz
