After 9 years of Stagea ownership I am out. The Stagea has been passed on to safe hands and should give the new owner years of fun. I'm sure I will be around but thanks to all here who have helped me over the years and to a few who may not frequent the forums any more but I still keep in contact with.
  • Like 1
Thanks Wolverine, for all the help you have returned to us. :)
What have you 'upgraded' to? I just can't find much worth replacing my Stagea with.
  • Like 2
Thanks Scotty, I bought the old man's 2012 335i which is a good car to steer. The refinement, the improved fuel economy, the interior is a bit more up to date but the car is less fun than my old R33 and the Stagea.
Finally got the Turbosmart Kompact BOV fitted, got a K & N panel and replaced the hid bulbs, which one has already failed, Yay for ebay!
Why a K+N? Don't say I didn't warn you. I only have a couple of AFM's left...
Rotors and pads arrived yesterday... R35 GTR seats should be fine to pick up next week.
My aero bar should hopefully arrive within the next 2 weeks :)
Nice one, pics please. :)
Forgot to mention, I had the AFM replaced at the same time as well :no:
Honestly didn't realise that K&Ns were an issue, for all the poking around ive done on here id not seen it mentioned.
Have noticed that at full tilt in 1st & 2nd, the last 3 - 400 rpm before redline, it drops off and then theres a slight backfire when it clicks into the next gear. It seems more noticeable now that the bov makes more noise too.
Once all the bits are in the spare room i'll get cracking and take some pics :)
Looking forward to getting these things done so i can move onto the next stage. I have a few blokes in Adelaide working on some options for me :)
Massive thanks to you too, Andrew, for helping with the original "Secret Squirrel Trick" for us PowerFC owners!
  • Like 1
Rotors and pads added today.
R35 GTR seats are still stuck in the container which they travelled from Japan in but hopefully they will be good to pick up this coming weekend.
Also got a bloke to give the M35 a once over to find possible issues.... Looks like i have some forum searching to do re: cv boots / caster rod bushes and radiator (last one will be easy)
Cheers
Cheers
If you are planning on modding it spend a little extra and get the moshimoto radiator. Twice as thick, twice as awesome. It is on my list of things to do this year.
I'll take a look Josh cheers,
Yes at this stage further mods will be on the way.. not sure how much more power it will make from the 240-odd kw's it's making now but i do see more in the future :yes:
Edited by Beregron
  • Like 1
post-137188-0-71712300-1428802621_thumb.jpgpost-137188-0-78468500-1428802650_thumb.jpg
Threw on the cold air kit today, idle seemed to go back to 650/750 rpm compared to the factory which I could never get to stay at. ?
And had a play around with the boost T, steady 14psi now bit more of a joy to drive ?
Now let's see who is the first to give me s**t for using a k&n pod and ditching the factory unit....
    • That was the first session so not a lot to take from the day. It was low 20s ambient and the coolant had got to 110 (and obviously had some pressure!) so that still needs to be addressed. I haven't downloaded the data yet but will. I had refilled the auto trans with Redline DT6 because it claimed the best viscosity I could find at 100o. It wasn't really long enough to get a good feel for that; while the trans got to 100o in the session it still wasn't shifting crisply as I hoped. I think I'll try a few more sessions before judging. No steering motor overheat but I'd hope not in only 1 session! But finally the suspension; it was night and day over the standard stuff and the car was a couple of seconds quicker on the same crappy tyres, which is a huge difference. I'll stick with that and get some sway bars and a mechanical diff sorted too and see how that all goes together
    • I guess it’s partially a compromise of how my car is used, wanting to be able to switch from drift to grip with track side on-car adjustment. Also partially with the way the knuckles are set there is more static camber but less dynamic camber gain.
    • OK, so update from the track day on Friday It was a classic "an unfortunate series of events'. There were a few cars around and when i checked my mirror coming out of the fish hook I notice some smoke from the rear of mine. Looked again and it was getting much worse, I figured I'd blown a turbo or something to got off it and pulled off the racing line. However.... since it is a left hairpin into a right kink, I was on the inside of the next corner. There was a car passing me on the left and a big drop off over the ripple strip on the right......and someone had knocked the witch's hat that was on the apex about 1m onto the track. So, between those 3, I decided to mow down the cone and not damage my car/the other car. Right choice, but surprising result.  The car decided the cone was a small pedestrian so it blew the rear bonnet hinges up to protect their head in the upcoming person to car impact....I didn't see that coming and like an airbag deployment it happened super fast. Straight into the pits from there, everything was driving fine but it became clear it was a coolant leak not smoke, it was billowing up onto the windscreen. Onto the trailer and home. I'll do a separate thread about the repair (once I work out what it is ), but the immediate problem was the bonnet wouldn't open because the front was pinched onto the front bar and would not release. Ultimately we unbolted the hinge from the bonnet, pulled it back a little and it released from the front OK. "There's your problem", the top radiator hose had popped off at the radiator.
    • Yeah that looks like great caster, but I'd suggest trying less front camber some time and seeing if it helps with braking without reducing mid corner speed too much
    • I ended up setting the rear 5mm higher than normal to give some clearance.  My plan is to run the least camber I can in the rear which I think with the extra width is going to need to be -1.75 to -2.00° just to get clearance.  Guards have been rolled and pulled as much as they can/I would be wanting to.  front has the Acostal knuckle with the KPI change and the drop etc. So should be okay with the existing settings I have run with AR1s etc Front: Toe total -2mm(1mm out each side) Caster +7.5° Camber -3.8° Ackerman +15°
