Successfully fitted the Greddy Floating Valve BOV which completely eliminates compressor surge and engine shudder.
Also the ECU no longer hesitates and dumps fuel.
Had a bit of trouble fitting the adapter flange as Nissan put the BOV mount right in the internal corner of the intake and it hits the raised collar where the rubber joiner abuts to.
Both the straight and perpendicular adapters have the same problem so just cut out some to clear it.
Perpendicular adapter will not work with the VQ25DET- puts the vent in wrong position.
Well worth the experiment.
Hmm that one will face the recirc vent at 45 degress up or down off horizontal - not ideal
Also the orifice looks small..
Remember the Greddy FV is a 40mm valve- almost twice the diameter of the Turbosmart Kompact which is 22mm.
So you need an adapter with a 40mm orifice to make the most out of it.
My understanding now for shudder with the VQ25DET is most aftermarket BOVs will not release enough air to deal with the slow closing electronic throttle.
Different story if you have cable..
So a bigger valve orifice and more tunable BOV solves the problem.
Fit Apexi GT reserve tank tonight with mot ul MoCool. just like Greddy radiator breath tank, but Apexi one could store more coolant (could store over 600ml radiator)
Edited by YangLIU
It would be ideal if you could bleed coolant up from the rear bleed point into this header tank; then bleeding the system would be essentially automatic.
Even better would be another line leading away from the low point of the tank, to the bottom radiator hose and use it as a fully fledged swirl pot system.
correct! that's what Greddy radiator breath tank do.
but for mine, the Apexi one, the bottom return line is connecting with heater hose outlet (it should be same as bottom of radiator hose). there is only one line on top which is to stock radiator top with zero pressure radiator cap.
next stage is using T piece replace stock air bleed port on heater hose inlet (i ordered some tools but they are on the way). then make a line from stock air bleed port with radiator top line together. that would make air bleeding be automatic.
Edited by YangLIU
So i finally decided to fit the rear leather seats and tan interior. I found that included in what i bought was a ARX option for rear middle seat seatbelt (photos attached). So after a full day all is finally installed but the passenger side seatbelt that was missing. I will need to keep the dark grey until i source another.
  • Like 1
Decided to drive to work Monday...
This is how i got home :P
lost hydraulic's in the clutch near work so i wasn't game to try and limp it home. No loss of fluid and the pedal would still return to the normal position... it was just the pressure point that went basically to the floor.
Have since had it checked by my mechanic who couldnt for the life of him replicate the issue. When i drove it the next day it was back to normal... My mechanic still gave everything the once over and adjusted a few things and so far zero issues.
Made me scratch my head tho...
Got a Innovate o2 sensor and looking at installing it onto my M35 and replacing the standard sensor with the simulated narrowband signal.
I've been under the car and the o2 sensor seems to be in an awkward spot. Is there a trick to remove them or do i need to take the dump pipe off
Brick managed to get a socket and extension on his whilst in situ; maybe pick his brains about this.
Here's how I got mine out: http://www.sau.com.au/forums/topic/459839-m35-dump-pipe-diy-install/
You can see the bung in the front pipe between the front flange and the flex which I will be using for my Innovate SCG-1.
Blitz front mount in today. Modified the supplied brackets and fitted slimline fan, like for the HDI kit so no cutting up the reo bar.
attachicon.gif2016-01-14 12.39.02.jpgattachicon.gif2016-01-14 12.44.42.jpgattachicon.gif2016-01-14 14.42.05.jpg
Bought from JustJAP?
Wont be long until someone comments on the orientation of the tranny cooler.....been there
Yeah, I see you had yours like mine but moved it sideways and into the guard. I thought airflow would be more important. Lots of conflicting views on orientation on the intergoogles. There was plenty of pressure when I last pumped out the old fluid so not too concerned about an airlock. You've got me worried I'm going to blow up my tranny now! :unsure:
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
    • -10 is plenty for running to an oil cooler. When you look at oil feeds, like power steering feeds, they're much smaller, and then just a larger hose size to move volume in less pressure. No need for -12. Even on the race cars, like Duncans, and endurance cars, most of them are all running -10 and everything works perfectly fine, temps are under control, and there's no restrictions.
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
