Successfully fitted the Greddy Floating Valve BOV which completely eliminates compressor surge and engine shudder.
Also the ECU no longer hesitates and dumps fuel.
Had a bit of trouble fitting the adapter flange as Nissan put the BOV mount right in the internal corner of the intake and it hits the raised collar where the rubber joiner abuts to.
Both the straight and perpendicular adapters have the same problem so just cut out some to clear it.
Perpendicular adapter will not work with the VQ25DET- puts the vent in wrong position.
Well worth the experiment.
Hmm that one will face the recirc vent at 45 degress up or down off horizontal - not ideal
Also the orifice looks small..
Remember the Greddy FV is a 40mm valve- almost twice the diameter of the Turbosmart Kompact which is 22mm.
So you need an adapter with a 40mm orifice to make the most out of it.
My understanding now for shudder with the VQ25DET is most aftermarket BOVs will not release enough air to deal with the slow closing electronic throttle.
Different story if you have cable..
So a bigger valve orifice and more tunable BOV solves the problem.
Fit Apexi GT reserve tank tonight with mot ul MoCool. just like Greddy radiator breath tank, but Apexi one could store more coolant (could store over 600ml radiator)
Edited by YangLIU
It would be ideal if you could bleed coolant up from the rear bleed point into this header tank; then bleeding the system would be essentially automatic.
Even better would be another line leading away from the low point of the tank, to the bottom radiator hose and use it as a fully fledged swirl pot system.
correct! that's what Greddy radiator breath tank do.
but for mine, the Apexi one, the bottom return line is connecting with heater hose outlet (it should be same as bottom of radiator hose). there is only one line on top which is to stock radiator top with zero pressure radiator cap.
next stage is using T piece replace stock air bleed port on heater hose inlet (i ordered some tools but they are on the way). then make a line from stock air bleed port with radiator top line together. that would make air bleeding be automatic.
Edited by YangLIU
So i finally decided to fit the rear leather seats and tan interior. I found that included in what i bought was a ARX option for rear middle seat seatbelt (photos attached). So after a full day all is finally installed but the passenger side seatbelt that was missing. I will need to keep the dark grey until i source another.
  • Like 1
Decided to drive to work Monday...
This is how i got home :P
lost hydraulic's in the clutch near work so i wasn't game to try and limp it home. No loss of fluid and the pedal would still return to the normal position... it was just the pressure point that went basically to the floor.
Have since had it checked by my mechanic who couldnt for the life of him replicate the issue. When i drove it the next day it was back to normal... My mechanic still gave everything the once over and adjusted a few things and so far zero issues.
Made me scratch my head tho...
Got a Innovate o2 sensor and looking at installing it onto my M35 and replacing the standard sensor with the simulated narrowband signal.
I've been under the car and the o2 sensor seems to be in an awkward spot. Is there a trick to remove them or do i need to take the dump pipe off
Brick managed to get a socket and extension on his whilst in situ; maybe pick his brains about this.
Here's how I got mine out: http://www.sau.com.au/forums/topic/459839-m35-dump-pipe-diy-install/
You can see the bung in the front pipe between the front flange and the flex which I will be using for my Innovate SCG-1.
Blitz front mount in today. Modified the supplied brackets and fitted slimline fan, like for the HDI kit so no cutting up the reo bar.
attachicon.gif2016-01-14 12.39.02.jpgattachicon.gif2016-01-14 12.44.42.jpgattachicon.gif2016-01-14 14.42.05.jpg
Bought from JustJAP?
Wont be long until someone comments on the orientation of the tranny cooler.....been there
Yeah, I see you had yours like mine but moved it sideways and into the guard. I thought airflow would be more important. Lots of conflicting views on orientation on the intergoogles. There was plenty of pressure when I last pumped out the old fluid so not too concerned about an airlock. You've got me worried I'm going to blow up my tranny now! :unsure:
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
    • The downside of this is when you try to track the car, as soon as you hit ABS you get introduced to a unbled system. I want to avoid this. I do not want to bleed/flush/jack up the car twice just to bleed the f**kin car.
