Yeah i feel the black head lining is a little too much. Would be different if i had black piller panels etc.
The upholstery and new liner will be done professionally. Not sure on cost for seats but got quoted 180 for the roof installed so thats a pretty good price. Essentially the interior will be black and beige/tan with burnt orange seats and silver highlights (door handle trims and gear stick surround).
The outside i am planning on doing a matt dark blue wrap with matt or gloss black wheels. Ill try and find a picture of the wrap for reference.
After putting up with a low idle for a week , yesterday took out throttle body to wash out with carb cleaner, gave it a good clean - hooray problem sorted.
Went for a good long drive last night to give it a good squirt, blew the passenger globe ! WTF its 6 months old.
Picked up a HID kid at 11, dismembered the front end and took the lights out. All complete by 13:30
While putting it all back together there is a whiff of coolant found that rad is weeping just near the cap :rant: . so now new rad time as soon as I order and it arrives.
  • Like 2
Fitted up a fire extinguisher today. Curse you Mighty Car Mods and your evil sidekick, Supercrap Auto!
Nice removable factory bracket on the non electric passenger seat so the extinguisher moves with the seat.
post-135423-0-20101400-1461413170_thumb.jpgpost-135423-0-00231200-1461413181_thumb.jpgpost-135423-0-39788000-1461413193_thumb.jpgpost-135423-0-74149800-1461413206_thumb.jpgpost-135423-0-36357900-1461413219_thumb.jpg
Yeah that's where they always split.
Think it happens to everyone eventually!
bought and fit headlight, it is 2nd one but near new, cant imagine it is over 10 ages old but still near new, compare with my old set.
now my world is clear again.
Edited by YangLIU
new part arrived yesterday :yes:
yet to do in the near future
exhaust modification
dump pipe
intercooler
intake
bc racing suspension
and new wheels
made as soon as the financial situation to give up :angry:
No big deal Josh.
You can get the 29mm recirc adapter and adapter plate from Nengun.
I used a Subaru adapter plate and just reamed the holes to realign them.
Just counter sink the plate and use counter sunk adapter bolts and take a nick off the side to clear the throttle body.
That's it.
It's well worth the install.
The valve travels so well, the intake recircs like it should.
No shudder, black smoke, dumping fuel.
Really smooth.
The Greddy is 40mm , Turbosmart 22mm, plus the Greddy FV is so adjustable with the two springs plus the wind in plunger.
By far the best thing I've done to this car so far.
  • Like 2
No big deal Josh.
That's it.
Really smooth.
I had a custom pipe welded up for $60, bought a couple of vac nipples to screw in and used a universal turbosmart kompact which had a 32mm base, easy peasy and asthetically good looking
Yes but to pay over 300 for one that doesn't bolt straight on against 189 for a turbosmart that does.....
adapter was easy to make an 8 mm aluminum sheet. but requires a little drilling, and grinding
the time it takes about an hour and the price of the adapter will be 2 €
Picked up a new driver seat today, happened upon it while checking out one of the local Up Garage locations...set me back a whole 20 usd
anyone happen to know the stock rail bolt size, I'm guessing 12mm but wanted to double check before I order a wrench, may just go ahead and pick up a ratchet set thoughHkC5bgbl.jpg
    • Hi everyone, I'm about to complete my first single turbo conversion on my R32 GTR and I thought I would post the step by steps that I will be following. I will list the parts I have / the parts I will be buying. I will be redoing this guide after I have completed the conversion. Parts list: - 3576 turbo 0.82 v-band (coolant and oil)  - v-band top mount turbo manifold - 50mm wastegate - manifold copper gasket - titanium manifold stud kit - turbosmart 3 port boost solenoid - link can lambda kit (wideband) - link ECU - radium 12AN push in valve cover fittings (pair) - hi octane catch can - 3.5inch downpipe - screamer pipe - pipe from turbo to intercooler - intake pipe setup - power steering relocation kit - oil drain block off plate - coolant and oil lines Now onto the step by step guide (please add / correct me if there's anything I missed: 1. remove fluids, twin turbo pipes, pod filters and afm's 2. remove the factory coolant hardlines from the hot side. 3. remove heat shields  4. remove the downpipe 5. remove turbos and manifolds 6. remove factory manifold studs 7. clean whatever mess you have made 8. install power steering relocation kit 9. install new manifold studs 10. install new turbo manifold with gasket 11. install new wastegate with screamer pipe 12. install new turbo  13. install new coolant and oil lines  14. install rear oil drain block off plate 15. stop and appreciate that you now have a single turbo in your GTR 16. wipe away tears of joy and install downpipe 17. install the wideband sensor into downpipe 18.install pipe to connect turbo to intercooler 19 .remove stock boost solenoid  20. install new boost solenoid 21.  install intake setup 22. setup the rest of the can lambda kit with the ecu  23. refill fluids and hope for the best 24. ask forums for help with issues 25. fix issues 26. drive your single turbo swapped r32 GTR into the sunset. Doneeeeeeeeeee. Now I know this isn't detailed at all but I will be doing that when the conversion is done. I will be posting pics and any helpful details i can and ill make sure to fit in as much information as I can. If there's anything I should know before i do this PLEASE let me know. Stay tuned for what's next. Thanks...
    • I have wasted too much time on this, more than I am willing to admit. I hope someone can set the record straight for me.  I want to replace my Nismo (non GT pro, non GT) standard 2 way in my R33 GTST with a 1.5 way... Ideally I want to get an ATS 1.5 way Carbon LSD, but I don't want to reuse my 29 spline 5x1 axle stubs, and new 30 spline 5x1's are impossible to get a hold of ($$$), and I don't want to drop the cash on going to 6x1 stubs and axles ATM. Which leads me to the Nismo GT Pro 38420-RSS15-B5 or RSS20, as they come with new axle stubs meant for the diff, and is "Convertible" from a 2 way or 1.5 way to "Other ways", but that is where I am stuck as the documentation is a bit all over the place.  To sum up what I have found I believe the all the Nismo GT Pro PN's are convertible from 2 way, 1.5 way, and 1 way; but Nismo sells 2 skus (2 & 1.5) so people do not have to disassemble to convert it.  I found this thread on 350z but it left the question unanswered. https://my350z.com/forum/engine-and-drivetrain/620032-nismo-gt-pro-lsd-1-5-vs-2-way-and-torque.html  Essentially the way I think it all works out is like follows...  2 way  1 way  and 1.5 way would be the center pinion shaft in the 1 way block, but with the with the center flipped 180*. So the ramped side of the pinion would face the 1 way gate and act like a ramp.    I can only get my hands on the 2 way in the states, and I am not trying to get stuffed on tariffs by ordering from Japan or anywhere else. I want to confirm that if I get the 2 way I can convert it to the 1.5.
    • Hi everyone, I have purchased my first GTR and I want to do a single turbo conversion to it. I've been doing as much research as i can and there are a few things that I can find and need to know. I need to run a coolant feed, coolant return, oil feed and oil return for my turbo setup. Here's what I know so far: On the hot side of the rb26 there is coolant feed, oil feed and oil return. Coolant return will be going around the front of the engine to where the thermostat is located. I will need to block off the rear oil return port. I will be running a turbosmart boost solenoid so any of the factory boost stuff wont be needed. Now onto what I don't know: 1. What do I do with the coolant / vacuum hardlines that run around the back of the motor?. 2. What do I block off or loop or move or remove?. I will be running the OEM intake manifold. 3. Is there anything in particular I need to buy for the cold side of the rb26?. I already have the intercooler and pipes sorted. If you have any pictures or information it would be appreciated. Thanks....
    • The fab work can be as simple as a couple of silicon hoses and clamps to the factory piping.
    • Just sounds like either way you need to do some fab work to get everything to fit, so why limit yourself at that point? If the GCG high flow option is zero effort in and out swap though I'd probably do that. It's almost certainly lowest risk, lowest cost, etc. The HKS GTIII-RS option that Kapr mentioned is laughably expensive for what it is, they charge the exact same for two turbos on the RB26 so their margins are off the charts on that thing.
