  • 2 months later...
Ok final tune done after adding Godzilla Motor Sport R35 coil kit new big fuel lines a flex fuel sensor & a Maatouks Racing crank & cam trigger kit.
98 tune…
E85 tune
thanks to Black Track Performance.
  • Like 3
  • 1 month later...
Finally got around to modifying the gear selector knob today, lot sleeker looking than the factory lump,and no more worrying about leather deterioration.
Was a bit of faffing around on the lathe back and forth but got there in the end , now that prototype works I can do the next one without machine marks and anodize centre shaft to black as well. Might even get a unicorn logo engraved or lasered in at some point.
  • Like 2
  • 1 month later...
On 08/01/2022 at 5:15 PM, SLIXK said:
What set up is that looks good
T67 style turbo on a China 🇨🇳 manifold that I got with the car @Garage48 in Hornsby modded it to fit an external gate turbosmart 45 mm (he did a great job highly recommended) he made a complete exhaust from the turbo back 3-1/2 inch with a cat and 2 mufflers. Plazmaman fuel rail intercooler and upper plenum. Bosch 1050cc injectors and a Haltech Elite 2500 it controls the Engine and Transmission it’s auto. That’s about it I think
How much kw did u end up making? How’s the haltech feel with the transmission?
Not enough needs a bigger turbo and maybe 700cc more as well 260kw at all 4. It feels faster than that so I can only assume it looses a bit through the trans an AWD. The Haltech feels like an ECU. But the transmission is great. Shifts nice and hard. Also has torque reduction on shifts to help preserve the box/flexplate. I am getting a complete MV automatics rebuilt trans and flexplate.
I have just had a built box from MV fitted with a full manual valve body and it is fantastic.
What stage box are you gonna be looking at building with them because my old trans is still sitting there at MV waiting to be shipped back to me and it's already got a stage 2 shift kit, all new solenoid banks that are about 5000 ks old, with a new set of clutches for 1st-2nd gear and bands fitted about 1000klms before being pulled out and swapped for the manualised one I got them to build me, so if you were interested at all I'd be looking to sell it for a lot cheaper than it'd cost to get all that stuff done.
Shoot me a message if interested RBWGN
Because the ecu controls everything I don’t need the manual valve body. So it will be essentially the same box as yours but with a different valve body to also allow auto shifting and shifting from the steering wheel.
Yep so the box that's still at MV is exactly what you have just described ,it has a stage 2 MV automatic shift kit so still works with tiptronic buttons etc and would chirp tyres into 2nd gear
  • 4 months later...
Edited by SLIXK
On 11/20/2020 at 9:37 AM, TMLP said:
Yeh its a Maatouks Racing built motor running 526hp at the wheels on 98, I was almost ready to get a flex fuel tune & turn it up to about 700 - 800. I think I need to upgrade the box as 3rd gear is the weak link so probably as you mentioned a 1st to 4th helical cut dog box will be needed. It will save down time & money in the long run. It is my daily apart from road bikes & I don't think I could put up with an auto or justify a sequential.$22K
Hey bro what’s your mod list? How much did your engine build cost aswell?
On 20/5/2022 at 8:01 AM, SLIXK said:
Mean bro, imagine how 300 atw would feel 🥶
To go much more I’ll need a different turbo. So the cost increases as I’ll change the exhaust manifold as well and probably go drive by wire but it’s actually plenty to get a not trouble with as with the auto you are always on it so there is no down time between gears
Fark I get down time in my auto, maybe it needs a service or upgrade lol.. 2nd to 3rd is so shit
Yes mine has a shift kit in it. There is not many people that could shift faster with a H pattern gearbox and keep the gearbox from exploding
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
