S1 Dayz.
Pic of the freshly painted brakes, because I just worked out that I can attach files using an iPad (yeah, yeah: I'm a slow adopter...)
Still have to tidy up around the engine bay: that wiring is embarassing... but you get the idea.post-39451-0-64102700-1377560237_thumb.jpgpost-39451-0-92587600-1377560277_thumb.jpg
Just received my Synx 6000, LS90 (diff oil) and bought some semi-syn gearbox oil the other day
Time for some loving for the stag
Oh, and polished the bonnet and roof the other day
My qutar window vents [what i guess you call them] started to flake so i decided rather then risk breaking them by pulling them of to respray i would cheat and plasti dip them insted [also alot cheaper seeing as i had left over and easier]
 *snip*
Hahaha every time i come into this thread i see one of my next mods all listed out.
I was going to do this exact same thing; also on silver stag...
:lol:
Hahaha every time i come into this thread i see one of my next mods all listed out.I was going to do this exact same thing; also on silver stag...:lol:
Twins...lol
  • Like 1
I think 13kms out of a rebuild is a good enough reason to look for a different engine builder. id expect a free rebuild on the 2nd one for that effort.
6th booking part one: never actually made it onto the dyno due to bottom end knock: engine had spun a bearing 13km after rebuild
S1 Dayz.
Still have to tidy up around the engine bay: that wiring is embarassing... but you get the idea.attachicon.gifimage.jpgattachicon.gifimage.jpg
I have been trying to figure out how to do this but can't get anywhere ( attach photos ) how did you do it.
...And that's exactly how it panned out...
Have to use the full site, then go to "more reply options", and you can attach from camera roll.
no idea if it works from iphone: too pokey, so I cbf trying.
Synx 6000 in - happy days
2+ hours rolling around the floor only to undo one fill plug for the rear diff - sad panda
who decided to make gearboxes and diffs so shit to put oil into?!?!
I think i'll pay someone to do this job
oh, and one of my headlights is out :(
fingers crossed it just the bulb
anyone have the link to the place selling the philips bulbs for a reasonable price?
On my M35, it's easy :w00t:
    • Why are people so insistent on making dirty water?!
    • Fark what are the changes of that snapping like that, clean. Nek minnit, custom radiator goes in, with built in oil cooler like those discontinued PWR ones from yesterdeacades ago
    • I thought I'd do a write up on an auto transmission fluid change for a the nissan 7 speed Automatic. At some stage the genius engineers decided that the fluid in the trans was "for the life of the transmission", (which seems kind of self supporting to me) and removed the dip stick and fill tube (funnily enough there is still a casting for it). Anyway, for this job you do need 2 specialist tools in addition to regular hand tools, jack and good chassis stands. You need a way to pump fluid up to the transmission; I got one of these but there are plenty of other options: https://www.ebay.com.au/itm/364584087070 Don't trust the generic listing though, it does not come with the required adapter for the Nissan 7 Speed. You need one of these, can't do the job without it: https://navarapart.com.au/product/genuine-nissan-patrol-y62-d23-np300-navara-re7-dipstick-fill-connector1 You need a heap of compatible transmission oil. Could be Nissan, could be anything else rated for Nissan Matic S. You need at least 10 litres, I had 15 to give it a better flush... Also, you need some biiig oil catch trays, at least one of these, or bigger if possible (volume was fine, size was very marginal): https://autobarn.com.au/ab/Autobarn-Category/Tools-%26-Garage/Specialty-Tools/Oil-Service/Garage-Tough-Oil-Drain-Pan-Black-16L---GT1068/p/TO03191 Finally, a measuring jug is very useful if your pump does not have volumes marked on it, I got a 6l one: https://www.repco.com.au/oils-fluids/fluid-accessories/measuring-jugs/penrite-measuring-jug-6l-pmj006/p/A5322648 Oh, and gloves.....this stuff is horrible (not as bad as diff oil, but getting there) ....First, jack up your car.....
    • So I mentioned the apprentice, @LachyK helped take the bonnet off. We just undid the nuts on the hinges and unclipped the gas struts, then pulled the bonnet back a little as the front was catching on the front bar.  I had a good look at everything today and have removed the rams, repaired/reset the hinges and bolted it back together like it never happened. I'll do a separate write up on the repair, and I also removed the poppers from the Fuga today too to save grief down the road.....as said above it is at least $5k to repair retail. I'm also happier about my ability to prepare a race car, and less happy about Nis-nault's engineering (I can hear @GTSBoy sAfrican Americaning) because the top hose of the radiator didn't slip off.......it snapped clean off. By practice I put the hose clamp hard up against the flare on a neck to make it least likely to ever move (thanks @Neil!). I guess that puts a little more pressure on the end of the pipe as it is further away from the rad, but still, that is pretty shit. I've put it back on for now as there was a fair bit of neck still there, but obviously there is no lip on the neck any more so I don't think I'll track it again until I have a new rad. Speaking of which....more research required. It looks like Koyo makes a standard size radiator in ally which I'll grab in the meantime, but I really want something thicker so might have to go custom in the medium term (ouch) Coolant still needs a refill and I have the pressure tester on it over night, but other than a wash down of the engine bay it seems alright. And @MBS206 noted something noisy on the front of the engine and I think I agree....time for a new accessory belt and tensioners I think.
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
