So you what do you think of this...
SAU Member: Kris..
rb20DET
HKS 25/35 turbo rebuilt by RotaMaster
JJR 38mm external watsgate
Supertech forged pistons 20thou oversized
ARP rod bolts
ARP head studs
Cometic metal head gasket
Cometic gasket kit
nissan oil pump
nissan water pump
nissan idler pully
nissan tensioner pulley
NDC bearing kit
HKS camshafts, 264/8.5mm
HKS cam gears
Gates timing belt
Tridon thermostat
crank was grub screwed, balanced and ground
balanced pistons
balanced and resized rods
block was decked, bored and honed
resurfaced head
valve grind
new valve stem seals
exhaust guides and ports cleaned up a bit
braided lines
GReddy returnflo front mount intercooler kit
Gkteck dump and front pipe
Blitz cat back
Splitfire coilpacks
JJR alloy radiator
z32 AFM
GTR injectors and resistor pack
Status remaped ECU
Walbro fuel pump
JJR oil cooler relocation kit
gutted cat
238rwkw @ 19psi
Me
Full RB20DET rebuild with upgraded rods and bearings (nothing forged as far as I know)
FMIC
Full turbo back exhaust with performance cat
Greddy Dump Pipe
z32 AFM
Cold air intake
Splitfire coilpacks
550cc injectors
Stock ECu remap
Garrett GT2871R
Bosch 044
Exedy Super HD Clutch
230.3rwkw @ 16psi Dyno Sheet R32 GTS-T.pdf
So the guy above threw 3 x as many mods into his 32 as me and only has 8 more rwkw and is running 3 psi more boost.
Can anyone explain this???
https://www.sau.com.au/forums/topic/351213-what-the/
Oh dude for crying out loud. Some reading before posting helps!
Every setup is different
Every dyno is different
Every tune is different
Every persons location is different (and this climate can be a factor in tunes)
You want any more possibilities?
Dyno results are a good guide, but to split hairs over 8rwkw is pointless.
If the dyno he is on, reads 10rwkw low, and yours reads 10rwkw high, then all of a sudden its 28rwkw.
You'll NEVER KNOW.
https://www.sau.com.au/forums/topic/351213-what-the/#findComment-5635828
Well that turbo would be prety close to being maxed out so its no matter what you do youll be struggling to go over with a 2535. At the end of the day you can have a full built motor with everthing you could possibly want on it and what would happen if you put a stock turbo? You wont make power.
https://www.sau.com.au/forums/topic/351213-what-the/#findComment-5635838
Different turbos, different tuner, different dyno.. unsure but his could make alot more power if the boost is wound up more.
also he seems to have done it the right way to make it all last and you seem to have the best turbo for your power range..
https://www.sau.com.au/forums/topic/351213-what-the/#findComment-5635839
You'll NEVER KNOW.
So why do we compare tunes then? If everything is subject to error/accuracy issues.
Why do you have a power thread to compare tunes? Why don't we tell everyone to do exactly the same mods and use exactly the same dyno at exactly the same temperature at exactly the same altitude at exactly the same geographic position at exactly the sime time of day.
Way to put a dampener on my day nismoid.
https://www.sau.com.au/forums/topic/351213-what-the/#findComment-5635845
SAU Member: Kris..
rb20DET
HKS cam gears
Blitz cat back
Splitfire coilpacks
JJR alloy radiator
z32 AFM
Status remaped ECU
Walbro fuel pump
238rwkw @ 19psi
Me
FMIC
Greddy Dump Pipe
z32 AFM
Cold air intake
Splitfire coilpacks
550cc injectors
Stock ECu remap
Garrett GT2871R
Bosch 044
i just removed the things that wouldnt effect overall power. he has 2 more mods then you. i could simplify the engine work by grouping it under "rebuilt engine" and im pretty sure it will be the same.
you pretty much have the same amount/type of mods but he is pulling more power.
peace out.
Edited by SECURITY
https://www.sau.com.au/forums/topic/351213-what-the/#findComment-5636257
    • Yeah and hence my ghetto way of slamming the brakes, get the ABS to cycle, rebleed seems to be a sensible workaround.
    • Hey! Happy to help. Nothing inherently wrong with the adapter, it's more so with Brett Collins himself. He gave me a lot of incorrect information when I was in contact with him and was extremely rude when I challenged him. He stated I could not use any aftermarket twin plate clutches except for his own, not to use the dush shield, bla bla bla and it was all BS.  Collins stated to cut roughly 14mm's off the housing, I took off 15mm to make room for the dust shield. I would confirm with whatever adapter manufacturer you're using.
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
