  • Replies 128
Yes. Shame the Albion pub was under staffed. Even with me telling em to have enough staff for the 30odd people that'd be attending the cruise, they never had a hope in hell trying to accommodate the 60plus people that actually came on the day.
Atleast the weather was awesome. Couldn't of been better.
Hi Guys,
I took some pics at the meeting point but unfortunately couldn't go on the run as I had to be home by 12:30pm......
Some lovely cars there though.....
Bob.
Edited by Aussie_Delivered_R32_GTR
lovely bunch of people, first time out with sau nsw since i moved up here. Hopefully many more to come....
Not as good as SAU VIC though (jokes jokes) :nyaanyaa:
It's not often on a meet that you have more gtr's than any other car either....very impressive ;)
Great day out guys, thanks to the organisers too. Shame about the late lunch but it was worth the wait.
I hope the donations bucket got at least half filled!
I managed to get some at the meet up point. Woodsy my passenger, will have his up later Pics up soon.
Was a great cruise indeed thanks to the organizers for making it so easy going... aside from the unplanned stop mid corner as duncan said luckily we were all paying attention :)
Me and a couple of others ended up just heading to trusty old macca's for a quick bite.
Even with faulty o2 sensors still managed to get almost 400km to the tank first time taking the gtr on a long drive in a long time... can't wait for the track days and other cruises later in the year :)
Was an awesome day. Glad to see people made it home ok. This must have been the longest cruise I've ever been on lol :)
With the donations, we managed to raise exactly $200 for the Queensland Floods!
So thank you to everyone who chipped in. Every bit counts and even peoples shrapnel helped alot ;)
Very surprised with the amount of people who turned up. Gives you an idea how many people lurk this forum :rofl2:
Humbla, I hope you made it home ok! Check your PM's.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
