Hey guys my name is Sherry.
My first Car was a Nissan Skyline TI. Now i finally have my full license i want to turn my car into a burnout car for events at eastern creek and summernats.
Im not too sure of what i want to do with it yet, But i want to keep it naturally aspirated.
I am thinking a 460 BB but i dont want to be greedy, also possibly thinking a 5lt. But i also do realise i need to consider power to weight.
Any Suggestions are more than welcome!!
Thanks :D
https://www.sau.com.au/forums/topic/351831-skyline-ti-burnout-car/
ok, I never even thought of the coyote, how do you think that would go with my engine bay though. would i have to change anything to be able to fit it in? Also how do you think it would go power to weight ratio??
Please excuse any "silly" questions, this is the first car i want to build myself :blush:
a mate of mine had a worked rb30E powered 31. went well for what it was, but a v8 would be better. know of another guy in town with a datsun stanza burnout car. pretty sure it has a natro sr20 in it. they start in 2nd gear and stay in 2nd gear. if the revs start to drop too much they give it a squirt of nitrous to pick the revs back up. you want torque for a burnout car so that you can get into the highest gear possible (the faster the tyres are going, the more smoke you'll get). this also means you can get plenty of smoke without having to keep it banging on the limiter, which helps with engine temps and engine life.
silly question.... rb30 E what does the E stand for? Also what KW did they get for that?
i like the sound of the coyote engine but also have to think of suspension n all that shiznit... im seriously leaning towards something of 5l or 5.7. If i go much bigger i think it will throw out my power to weight too much
:rolleyes: i am a sucker for Muscle though, coming from a family of mechanics
I want something to stand out from everything else. Hence why i dont want a turbo.
You want to stand out but you want to put a V8 in for something like Summernats...
Windsor 302...can get them dirt cheap, will be fine for the weight of the car, can get in carby or EFI configuration, relatively small engine, myriad of aftermarket parts available.
The E in RB30E stands for electronic fuel injection.
Ahhhh ok, thanks heaps. something to consider :thumbsup:
How much r we talking about?? or i had a suggestion for a LS1 and putting a manualised turbo behind it to get decent power to weight ratio?
any v8 conversion will cost a bit of money in fabrication (engine mounts, gearbox mount, custom tail shaft if needed) but will give you good results for a burnout car. a LS1 would be good since they are a light motor (lighter than the stock RB), and they are relatively cheap these days. hardly different though.
if you want to be different, try to squeeze a turbo 'BARRA' 6 engine (xr6 turbo engine) in there. might be a bit of a squeeze and will put a touch more weight over the front end, but they have a buttload of torque, are easy to make good power out of, and it will be pretty much one of a kind. just might not fit in with the v8 bogans at summernats as well as a v8 would though.
im putting a 357 in it .. getting quotes n shiz as we speak :rolleyes:
Cleveland, Windsor, SBC or Mopar?
I doubt a cleveland will fit without chopping the strut towers out, sames goes with a 351 windsor.
either way, big engine + little engine bay means epic overheat before 3mins is up.
Ever notice that all the engines that go pop due to overheating in burnout comps are those in little cars, eg toranas, cortinas, Rx4s etc
cleveland.
I'm not going short with this car. The engine for what i want will cost at least $40,000 if not more.
Plus the diff and tailshaft im getting will definately be able to handle the h/p that comes out of it.
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
