my new forged engine is using about 1 to 1.5L of oil per 2500km
compression test shows 155 to 160psi across the board
i cant see any oil leaks.
very little oil in intercooler piping.
have been told the car blows the blue/black smoke under throttle.
the motor does breath quite a lot (white smoke out of the oil cap when removed).
i get a (brown water) like liquid in catch can.
im hoping it is my turbo seals
can a turbo seal leak into the exhaust housing and not the compressor housing?
so i ask can anyone shed some light on this problem.
cheers
Ryan
https://www.sau.com.au/forums/topic/351911-forged-engine-using-oil/
do a fairly agressive leak down test on it (@ operating temp), it will tell you whats going on.
Here's one we did not long ago.
CYL COMP LEAK DOWN
1 155 10-16% @100-110psi
2 155 10-16% @100-110psi
3 155 10-16% @100-110psi
4 155 10-16% @100-110psi
5 155 10-16% @100-110psi
6 155 10-16% @100-110psi
http://www.carcraft....ster/index.html
i have found another symptom
some times when the car is running only on cold start i believe have not confirmed this yet
if you hold your hand behind the exhaust you get little black specks on your hand i believe this might be the oil i'm loosing.
please share your opinion but i believe this to be a good sign that the turbo's are leaking the oil.
my reason for this is the if it were the rings the oil would be burnt rather than spat out the exhaust.
also i assume that this would only occur when the exhaust is not hot enough to burn oil hence only happens on cold starts.
what are your thoughts people
sorry but that's normal. it's just a build up of moisture and carbon blasting out the exhaust on start-up. I've owned over a dozen GTRs and all have done it. it's not oil. my old GTR with no cat etc painted the wall behind it completely black after a short while just due to that.
Are there any oil stains on your driveway/garage? I
would suggest getting the whole engine degreased properly on a hoist, then drive the car for a few days and see if there any leaks.
if there aren't any physical leaks then it sounds like it maybe worn valve guides or valve stem seals
"my new forged engine is using about 1 to 1.5L of oil per 2500km"
+1 for leak down test.
+ my 2cents
Check for wet oil on plugs to see if your oil is being pushed up/sitting on top of your pistons,
Drain oil to see if there is fuel in your oil pan.
Consider not driving it, if you can, until you work it out as it can lead to another re-build..
You could send the oil away for analysis - that can tell you if there's abnormal piston/ring or bearing wear, how much fuel is in the oil etc.
If its using oil when on the throttle it generally wont be valve guides or seals, that generally only happens at idle and on decel. Oil burning under load is usually always rings. Could be wrong cross hatch angle, damaged rings, scratches in bore from improper assembly or dirty assembly, poor initial break in and the list goes on.
Have you done the leak down test yet?
when my turbo seal went I had this exact problem, compressor made love to the housing not long after. Never checked the catch can though as it is a gay one where I have to remove it to drain it.
Edited by Rolls
yeah I would be sending the oil away for analysis. it's cheap (under $50) and will tell you what is going on. and yeah get the leak down test done too, it's not hard.
i jacked the car up nice and high to day and i have noticed i have an oil leak
it appears to be the return oil line for the front turbo.
general area around is oily but not dripping!
i am pleased to have found this as i have a new set of gt2860-5 along with Tomei manifolds and dumps to go in the next 2 weeks
i hope this is the only oil consumption
to lose 1-1.5l per 2500km it should be soaked.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
