Well given he's done "a few hard laps at the track" I'd say somehow the oil was still managing to flow throughout the motor. Even 5 minutes of driving would completely ruin the engine...
Yeah I'd check it.
I had a thermostat on the oil lines that bypassed my oil cooler if oil wasn't hot however it didnt flow well enough and I ended up with a spun bearing.
Can always try bypassing the cooler by removing the cooler in hose and looping straight to the engine to see if it makes a difference to the low oil pressure you mentioned.
im hoping it was all ok... i still had plenty oil pressure when running the motor etc. so i guess the pressure valves must have popped. lucky i'd say
is having the oil coolers inlet and outlet on the bottom a bad idea?
Depends on what kind of cooler it is. With some designs it will not fill properly from the bottom.. If you turn it on its side and have entry at the bottom that will be ok or have the inlet and outlet at the top.
not sure mate but putting 2 in the pink and 1 in the stink isnt a great idea, u'll get shit on your pinky, better off putting 3 in the pink
  • Like 1
  • Nope 1
oil analysis, its like $50 and mainlube.com.au do them, highly recommended, will tell you if you have shagged the bearings or anything.
this is something you want to find out now before catastrophic failure, it could be fine though.
+1 for oil analysis ..at least you know exactly what condition your bearings are like.
Or just keep punishing the engine as you normally would ..you will find out soon enough if its good or if its f*cked.rolleyes.gif
Some oil "should" have gone through the over pressure bypass built into the factory oil warmer, if you have removed that or a running an RB20 one you will be in trouble
This pressure bypass is all that kept my engine running. My engine still ran fine, no rattles or any bad noise. It was just all the metal in the oil that worried me. It wasnt worth the risk to fix the lines and keep running the car so I had it pulled down.
nah i wouldnt say full. i drained the oil into a clean bottle that wasnt black, cut the side out of it. then poured it into a waste drum and left a bit in there. holding it in the sun reveals the oil to have a metalic sparkle to it. and then right at the bottom was a couple of tiny metal flakes.
so yeah.. pretty clear damage has been done.
bummer. sorry to hear that mate. :( yeah if the oil has that nice metal film and some sparkle to it chances are that's your bearing coating in there. what a bugger.
did an oil change today.... and well... not the best result :(
dont think i'll need to send an oil sample off. that will be 50 i can put towards a new motor i think
Hope your result isnt as bad as mine.
My oil looked like mercury with lots of chunks of bearings lol
Edited by WHITER33GTS-T
nah mines not that bad. have spoken with a few engine builders and they have all said it looks like the start of some bearing wear and that placing a life span on it is impossible.. could last a day could keep going for another 12 months. Gonna start building a spare bottom end i have anyway i reckon!
sorry to hear that.
if it has picked up some bearing already, pull the motor. it only gets more expensive (more needs replacing) the longer you run it.
I would know, I've done it often enough lol. My record for a motor with incorrect oiling was 50klm from new to bearing spun
    • I hope it's actually possible. This is a write off in insurance world.
    • Yup. 2-way with shallow ramp angles. Still works.
    • That was the first session so not a lot to take from the day. It was low 20s ambient and the coolant had got to 110 (and obviously had some pressure!) so that still needs to be addressed. I haven't downloaded the data yet but will. I had refilled the auto trans with Redline DT6 because it claimed the best viscosity I could find at 100o. It wasn't really long enough to get a good feel for that; while the trans got to 100o in the session it still wasn't shifting crisply as I hoped. I think I'll try a few more sessions before judging. No steering motor overheat but I'd hope not in only 1 session! But finally the suspension; it was night and day over the standard stuff and the car was a couple of seconds quicker on the same crappy tyres, which is a huge difference. I'll stick with that and get some sway bars and a mechanical diff sorted too and see how that all goes together
    • I guess it’s partially a compromise of how my car is used, wanting to be able to switch from drift to grip with track side on-car adjustment. Also partially with the way the knuckles are set there is more static camber but less dynamic camber gain.
    • OK, so update from the track day on Friday It was a classic "an unfortunate series of events'. There were a few cars around and when i checked my mirror coming out of the fish hook I notice some smoke from the rear of mine. Looked again and it was getting much worse, I figured I'd blown a turbo or something to got off it and pulled off the racing line. However.... since it is a left hairpin into a right kink, I was on the inside of the next corner. There was a car passing me on the left and a big drop off over the ripple strip on the right......and someone had knocked the witch's hat that was on the apex about 1m onto the track. So, between those 3, I decided to mow down the cone and not damage my car/the other car. Right choice, but surprising result.  The car decided the cone was a small pedestrian so it blew the rear bonnet hinges up to protect their head in the upcoming person to car impact....I didn't see that coming and like an airbag deployment it happened super fast. Straight into the pits from there, everything was driving fine but it became clear it was a coolant leak not smoke, it was billowing up onto the windscreen. Onto the trailer and home. I'll do a separate thread about the repair (once I work out what it is ), but the immediate problem was the bonnet wouldn't open because the front was pinched onto the front bar and would not release. Ultimately we unbolted the hinge from the bonnet, pulled it back a little and it released from the front OK. "There's your problem", the top radiator hose had popped off at the radiator.
