Txt me on 0421549607
rb20 bare motor (or can come with bolt ons just ask) $500
Comp tested this week 140 on all cylinders
Rb25 box $1100
Hardy spicer tailshaft suite rb25 in r32 $200
HSD coilovers r32 set base height adjustable $600
Velo gp90 brand new L $650 comes with plates to mount
Sparco deep dish wheel genuine brand new $250
kazama s13/r32 castor arms &150
Rear ISC camber arms suite same $100
s14 power steering rack new boots, rod ends and lock spacers $100
nismo engine mounts rb20 brand new $100
Parting complete r32 just ask for parts got lot of stuff
Text me don't pm me
Pair of GENUINE Bride DIGO-R seats and rails for R33 GTS-T, purchased from Japanese Import Spares 18 months ago, seats are immaculate, no rips/tears/stains etc, just a little dusty from car being in storage.
Selling due to going to Cage and Fixed seat.
Retail for $1K a seat, and $200+ per rail, selling for $1200 as a complete bolt in package. No separating the pair, nor the rails.
Contact Ben on 0439 888 043, or PM here, Car is in storage @ pooraka but seats will be removed tomorrow and can picked up from modbury. Can also help with delivery.
Bump, still for sale.
R32 Skyline GTS-T
Wide Vented Front gaurds
+30mm (same size as R32 GTR guards)
fits 17x9 -5 245/40/17 without rubbing
$100ono
pickup from AUSJAP during business hours
4 Westport Road, Edinburgh North SA 5113
0416580223
Edited by CRSKmD
I've got a couple of 4wd RB25DET blocks and heads that I'm wanting to get out of my parents shed.
Both motors have low compression.
Both have sumps and rocker covers off, one is missing an intake cam.
If you are after any bits and pieces let me know.
up for sale is my pride and joy, high powered performance gtst. which is also featured in the zoom magazine, previous owner had set this beast as a track car, also spending a lot of $$$ on it has one at import monster sau nats 2012 for quickest 800m mod 2wd class.
also at import monster sau nats 2012 800m highest speed mod 2wd class.
there is no back seats and carpet had been removed, has a bonds half cage $700 installed
has two r34 gtr bucket seats.
gtr rear end
omp race spec stearing wheel
a set of $700 defi din gage for oil,press,water,oil,temp
has a zetronic ethanol display screen $500
nismo gtr 320km cluster white $1000
phantom boost gauge $220
fully enginerrd certificates so hassall free
motor rb25 30 to4z turbo water and oil cooled
2000cc injectors areo flow fuel rail
all braided lines runs from engine to the boot and connects to a 5 ltr sard fuel surge tank with x2 walbro 450 in tank pumps
nismo in tank fuel pump to exterior
has an immobiliser built in too
x2 fuel location for exterior pumps
also has an e flex sensor so you can use petrol or e85 sensor and computer does the rest.
huge plenom with qhf 90 mm throttle body
Ross cas full balanced
drilled out oil remains blow off is plumped back
blisten shocks all new bushes
sway bars in boot engine bay under Neath sway bars
r33gtr wheels with brand be hankook tyres $1500 for set of 4
response head unit alpine speakers
brakes upgrade to dixcel type gs slotted rotors with zpads $2500
has also just put in a PPG dog box 1st to 4 gear straight cut 5 normal gear $8500
also has a nismo twin plate coper mix clutch but good friend jim berry had it supped up for me costing $3000 but strong guarantee it will last
r33gtr rear end 4:11
also eagle conrods, je pistons, custom exhaust camshaft (256deg) single coil up rated springs drain back vents on head drilled out oil returns rb26 cam covers with mines baffles external oil feed1mm restrictions full balanced QF45 throttle body high energy oil sump, tomei oil pump, factory Ross cass balancer, gready intake manifold, custom front mount inter cooler, Phoenix alloy radiator, custom 3.5 inch 5zigen exhaust system, high current igniter, link g4 plug in engine management system with link 2bar map sensor gready profec and electronic boost controller
the whole e85 fuel system cost $7600
car mad 450kw 601hp ran 11.08 at creek with old box be easy 10z with new box
car has receipt for every thing no joy rides no time wasters $27000 no less over 60k worth of grunt and power munches any thing on the road on low boost.
car also is featured in zoom mag custom plates SKYLNE also has 3 boost settings off is 14 psi low is 21 psi and a high 26 psi
call me on
0437797237
powererd and tuned by unigroup enginering!..
Still here, price drop to $1K firm for both seats and rails.
Hai.
Got a few things..
R32 centre vent, good condition. $100
4x114 17x9.75 xxr527, good federal tyres. $350 firm.
Gktech lock spacers. Unopened in packaging. $10
Random yellow and black momo steering wheel, no boss. $10 or a longneck of woodstock.
Have a few r32 interior parts if anyone needs anything i may have it. Most things aside from back seat, door trims or pillar covers.
  • 3 weeks later...
R33 RB25DET Gaskets - brand new genuine Nissan exhaust (14036-21U00) and intake (14035-75T01) gaskets. Exhaust $50, intake $30. Intake gasket got slightly bent in transit because they put some head bolts in the same box, but looks fine to use - welcome to have a look if you are interested. I don't want to post these - they are too hard to package. Pickup in NE suburbs (of Adelaide) or can drop off around the city.
Also have a set of new OEM rings - see listing in general for sale section.
Edited by GeeDog
Gktech dished 350mm steering wheel, comes with horn button, was mainly used on racing sim rig - $50
Gktech GKTech v2 front castor arms to suit S13/R32, was in the car for 1 track day - $100
Sparco Sprint Junior, smaller sized fixed back bucket seat and in good condition, is missing plastic frame where the seat belt goes on left side but doesn't effect the seat at all, Seat only no rails. - $200
Located in the Western suburbs.
Pair of GENUINE Bride DIGO-R seats and rails for R33 GTS-T, purchased from Japanese Import Spares, seats are immaculate, no rips/tears/stains etc, just a little dusty from car being in storage.
$1000 the pair, are now out of car, will give a good vacuum and clean.
Moulded fibreglass sub enclosure for R33, moulded for driver's side, for 12" Sub, never used - $100.
Genuine Nardi Classic 360mm in leather, and Unknown Detachable hub kit in black - $100
Factory R33 Floor mats, complete set of 5 - $50
Finally, APexi Power FC, Z32 AFM, APexi Power Intake filter, Stainless Lobster-back intake pipe, TLF Performance 550cc injectors, Denso 255 LPH Fuel pump - $1000 the lot, PFC currently tuned for those mods and Trust TD06L2 - 20G 10cm turbo kit. All parts currently on car, but will be removed over the next day or two.
Don't want to separate this at the moment, but will if i have enough interest in it all. All the following are less than 12 months old, and have done less then 5000kms. Selling due to going haltech and E85 fuel system.
Contact Ben Here, or on 0439 888 043. Parts located in Pooraka, or can assist with delivery.
**For Sale**
Brand New R33 GTR rear pods with stickers still on there, in black gel coat, put them up against the car to test fitment and they fit pretty good! Open to Reasonable offers 0423639141
Are these still for sale and what kind of price are you looking to get for these?
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
    • You can use your VIN to look up the factory part number somewhere like amayama, and then look to order new if necessary. https://www.amayama.com/en/genuine-catalogs/nissan Depending on price you might want to rebuild instead. @GTSBoy I had an interesting insight into US market parts when the Titan rear calipers were sticking. New calipers were dirt cheap, about 20% more than a rebuild kit....they are just considered throw away maintenance items
    • Funny, but really not funny. Thank god (most) f the world has moved on since then
    • Lots of votes for driving onto a plank first; that is the quickest way I've found, 25mm is enough for my case but that will vary by car It also depends where you are going for. On the 32 I can get to the rear diff with my floor jack if I do that end first, and get it up on stands. Then I lift the front from either front tow hook as high as needed, also onto stands. Sometimes I need a small lift on the other tow hook to get it level enough If I do the front first I can't get to the rear diff because of the angle of the car Other options are getting to the front mount of the rear subframe from in front of the wheel (if only lifting one side, or just do both which is a bit of a pain compared to one lift from the diff), or also the gearbox cross member mount on the driver's side if you are  just trying to lift the driver's side. I This is the jack I use; it says 75mm clearance but of course that is only on the lower section so if you have to reach too far in like the diff you still get stuck. https://www.snapon-bluepoint.com.sg/category/Floor-Jacks/product/Floor-Jack,-2-Ton-Low-Profile
    • On the bright side, the weather will turn much nicer for working outside shortly....sounds like you might need to start on a neighbour's garden next
