R33 GTR Intercooler with reducers $250
Turbosmart: Dual Stage Boost Controller $150
VG30 Ball Bearing Turbo - Little Bit of Shaft Play $350
PM all offers
All Prices Are Negotiable
hey mate, can you PM me photos on the Intercooler?
hey,got a couple of things for sale
CAPA performance intercooler,same side inlet and outlet,both 2.5inch (i used all stock piping +minimal extra piping) brand new when purchased,done roughly 6000km on my stagea,couple of bent fins(nothing major) was chrome but has been sprayed matte black
pm me for measurements (its quite big) $300 ono
NISMO R33 gtst rear coilovers,in good condition,only damper adjustable 4ways,no knocking,bought to fit my stagea but didnt fit properly (different hats) few scraps and dents on them but dont affect to function of them at all,could do with a clean but i cant be arsed
$120 ono
R32 gtr rear tanabe sustec struts and springs,excellent condition,recently cleaned,no leaks
pm for pics
$50
also have a series 2 stagea dayz edition lower front lip made by dolphin,pm for details on that item
negotiable on all items,im after some 20mm spacers at the moment so could maybe work something out
pm or sms 0421754575
thanks
thanks
pm sent regarding 'cooler
6 x 440cc (Top Feed) injectors for sale
came off a '89 R32 GTR
have been flow tested and are good.
will fit RB26,RB20 and SR20(i think??) NOT RB25
$300
0421 125 183
Edited by Brezza
For Sale:
Greddy Type S BOV with RB adapter = $200
R32 Steering Wheel = $50 (good cond.)
Vertex Rear Bar for R32 = $250
Greddy Turbo Timer = $100 (comes with detachable harness for R32)
PM me
Item: Genuine Trust T88-34D
Age: Unknown
Condition: Mint, no shaft play
Price: $1700 ono
To Fit: Anything
Contact: PM here or call 0423929657
Comments: The turbo was bought of a fellow forum member, i was told that the turbo has done under 5000k's, ive had it checked out and is in mint condition. It was bought for my rx7 fd but it will fit any car, reason for sale is i got defected so im just going to keep the motor standard.
got the mrs 92 holden nova for sale as she has decided that she needs the stagea way more then i do.
10 months rego
air and power steer
manual
neat interior
paint abit faded
needs a set of tyres
$2000 as is or $2300 with new tyres. will make a good daily/first car.
not sure if there is any aquarium hobbyists here, but ill try any ways...
i have 14.5 kgs of crushed coral, perfect as a substrate for cichlids as it keeps the pH up.
i paid 90 bucks for 25 kg bag, and only used 10 kgs in my 4 foot tank.
the remaining 14.5 kgs will be plenty for a 6 foot tank, or anything smaller.
40 bucks.
FOR SALE:
Fisher & Paykel 'Excellence/Smart Drive' 6.5kg digital panel washing machine.
6 years old. Hardly used in last 2.5 years. Excellent condition. No leaks, no fuss.
$140 ono
PM me
    • Increasing overlap will bring the torque down earlier (and make your idle sound sick lol). Worth a shot (if you dyno time) to experience a bit (providing you are confident your valves won't kiss your pistons). Is to just take off 5 degrees across the boosted area of the map, and then retard the exhaust cam let's say, 3 degrees at a time and then overlay all the runs with VCT on all the way and VCT off as soon as you make positive pressure. Ideally you would have a total of 6x overlays to looks at 0 exhaust & VCT off once manifold pressure is +ve 0 exhaust & VCT on all the way -5 exhaust & VCT off once manifold pressure is +ve -5 exhaust & VCT on all the way -10 exhaust & VCT off once manifold pressure is +ve -10 exhaust & VCT on all the way Just leave your O2 wideband closed loop on for all of the boost area & RPM, and hopefully there isn't too much fuel correction needed and the Haltech is fast enough to compensate (I do this, then apply the correction to the main table). Getting that overlay data should give you a good indication of what to aim for.
    • So, my main limitation here is that the car does not have an oil pressure sensor by default, just a switch. As part of my tune I bought an oil pressure sensor upgrade so I now have access to oil pressure levels and logging rather than just the boolean behaviour of the switch but this means I need to use the tuning app to display this value. So, this rules out using any other app on the iPad. The app will also flash when pressure drops which is a nice feature. I have replaced the centre screen with an Android one, which is awesome for Android Auto, but I think it might be too far away and out of my line of sight. I might add some gauges to it this weekend and just see. I guess if its just temp and oil pressure I can make them massive! 🤣
    • This is what the look like normally. Except we only got the 2 doors locally
    • Back pressure is not really a function of the exhaust itself, but the turbine/housing. So the question/point remains valid. I would be fitting an EMAP tapping point and seeing what is going on in the exhaust manifold before committing to throwing boost at it. Flow. No intercooler is actually rated for continuous operation at any power level wrt temperatures, as they are no actually capable of shifting the required amounts of heat on a continuous basis. They get hot during a pul, then dump some of that heat into the external air (and some back into the internal air) during off load moments/periods). You probaby do need a bigger core, given the power level you're already at is somewhat above the "rating" of the cooler. Put pressure tapping points either side of the core (which possibly you already have, if you have a boost source near the compressor outlet and tapping near the throttle for existing purposes) and report on delta P across the core.   I haven't done the mass flow calculation to see where you would be sitting on the compressor map at the ~450is rwkW level we're talking here, but if you look just at the PR you're running at, which is ~2.8-2.9, then you have a really really wide swath of the compressor map to run in, and so long as you were making between about 45-75 lb/min of flow, you should have really good comp efficiency, with the ideal being betweem 55 and 65. I can't see the need to shift drastically on the map to get better results.
    • Welcome 🙂 The ER34 wheels and slight lowering suit the R33 sedan really well. I'm firmly in the 'keep it stock, at least on the outside' camp.
