having met john and spent a few hours(!) talking to him I have utmost respect for the man. he has amazing skills and a brain that operates on another level to most. I have a pretty high IQ but john must be off the charts. Very nice guy too and not afraid to tell what he thinks and usually has very sound arguments to back his opinions too. he has some amazing ideas about a whole range of stuff.
I've no doubt this will be off the charts. I want to go back and ask him some more stuff. just need time for my brain to digest the last bits of knowledge he dropped on me!
thanks very much bobby. I really appreciate the intro mate. and your time too. :)
You lucky duck!
Hey Richard,
Glad that you liked the meet with John.
Yes it does get like that, does take time in digesting his knowledge.
Speak soon
Below pic, I have installed the Zeitronix Ethanol content sensor that gives you the concentration of ethanol in E85 Fuel. This is a must when running E85, last thing you wont to do is give it a hit and you lean out cause the ethanol content has changed, this is connected to a return line. Just Engine management is a Dealer for Zeitronix products.
http://www.zeitronix.com/
Theres a writeup in the Forced induction section if you dont check it often, by a guy who has used that sensor with a Link ecu, a local tuner has got the car running on anything between 98 and E85. Check it out, good read.
Yes very well put together thats if you want to run 98 and E85, what i am trying to do is only run E85 however as you know the concentration varies so we need to know the ethanol contant accurately . Tune can vary to fuel temp also when using E85 i have noticed he has not allowed for that.
What's the plan to alter the mixture of E85 if it is found to be varied from the original tune state? Add denatured Ethanol and/or BP98?
What do you do with ignition tables in regards to varying ethanol content/fuel mixtures? Add an extra dimension vs ethanol content? Sounds like an absolute mission to get running at an optimum level.
I'd think that the optimum/safe ignition advance would vary widely when you started mixing fuels together, as opposed to making ethanol content based corrections to the fueling table which would correlate directly to ethanol content..
Below is an update of the wastegaste Venturi.
Progress has been slow as John is having alot of problems panel beating the 304 stainless as it needs to be annealed every time he needs to beat it and the time frame is short before it cools.
Looking great!
was at outback steakhouse with him couple nights ago
    • Yes, I know🙄 but the sequential is not in my budget... don't want to reduce power neither, so looks like I'm stuck in the rabbit hole🤣
    • You’ll be very upset when you bust that too not to mention the gearing totally sucks. Don’t do it.
    • Is the panel filter one that is oiled? Have you ever cleaned or touched the AFM?
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
