after having several cars almost merge into me with my hand on the horn - i've decided that my car horn just doesn't have the impact that it should.
so I was thinking of grabbing one of those "stebel nautilus" ones from ebay. they say the dB is 139dB and up depending on the model you get. i've heard the horn and it sounds like it would get peoples attention
Does anyone know if there is a max dB level that can be used for a horn? or is it a case of, as long as it's not the musical type and constantly on, its all good.
Cheers
https://www.sau.com.au/forums/topic/355633-car-horns/
The horn on the GTR is very poor, almost apologetic... I've tossed up the idea of getting one of those aftermarket ones for a while now. The Clio has a great horn, as do a lot of Euro cars, have thought about checking out a wrecker for a second hand one, but those stebel ones seem pretty cheap...
https://www.sau.com.au/forums/topic/355633-car-horns/#findComment-5693961
This is what i found for NSW not sure whether it applies to the whole country. EDIT: Maybe you should call the EPA or someone like that and get it from the horses mouth.
Noise from motor vehicle horns
Horns cannot be installed or used if they are louder than the level in clause 21 of the Regulation. This level is 120 decibels for noise made up of a single non-varying loudness and pitch or 85 decibels in any other case.
Police and Emergency Service vehicles are exempt.
Horns should be used as traffic warning devices only and not as a means of relieving driver stress or frustration.
http://www.environme...ehiclenoise.htm
Edited by Shazza24
https://www.sau.com.au/forums/topic/355633-car-horns/#findComment-5694021
Haha yeah... This thread inspired me to research it a bit more.. It came on my car from japan..
I found it on google... It's actually a cool bit of kit..
Has two modes controlled by a switch... The box advertises the as:
"PA!!!!"
And...
"PAAAAaaaaan"
Haha basically u flick switch and it turns it into a tapered sound like a train
https://www.sau.com.au/forums/topic/355633-car-horns/#findComment-5696743
You need to get one of these. Maybe get one with a carbon fiber warp and mount it to the pillar? Perhaps put a neon light inside it?
If I get cut up by some hoon I find it therapeutic to imagine the rubber end is the guys scrotum? I can work out my rage by squeezing and twisting it, whilst simultaneously making an aural expression of my displeasure. :)
https://www.sau.com.au/forums/topic/355633-car-horns/#findComment-5696812
Someone cut in front of me this afternoon, and I actually went through the mental process of
*idiot*
*I'll horn him*
*actually, that's right, I'm in the GTR, this horn is p*ss poor so it's going to sound pathetic*
and I let it go.
The R34's contribution to a more utopian society.
https://www.sau.com.au/forums/topic/355633-car-horns/#findComment-5697910
Get a Vuvuzela...
I actually used one of these out the back window of the old mans Mitusbishi express. Travelling back from the Bathurst 1000 on the Bells line of road. Nearly got cut off by a silly woman, so blew the f**k out of one of these at her and she broke so hard she locked up the front wheels!! :cheers:
  • Like 1
https://www.sau.com.au/forums/topic/355633-car-horns/#findComment-5698008
i bought a set of air horns for my silvia because i was sick of getting cut off by tards in traffic.
anyways, at first the two horns weren't that loud but i had the brilliant idea of only using one horn. so double the air into that horn would make it louder and it made a huge difference. It's quite a lot louder then a normal "beep" horn.
I was thinking about buying another air compressor to increase the volume even more.
Edited by Peter89
  • Like 1
https://www.sau.com.au/forums/topic/355633-car-horns/#findComment-5698546
I'de edit your last sentence, while you still can hahaha.
https://www.sau.com.au/forums/topic/355633-car-horns/#findComment-5698562
Was the biggest disappointment after buying my GTR.
First time I hit the horn ( I use it a lot in Japan with the amount of idiots on the road) I wanted to crawl under a rock and hide.
My misso's Jimmny's horn was way,way louder.
Not anymore. Change of horn was my first mod.
I always love winding up the staff in Super Autobacs with their air horn display.
Bunch of horns all wired up with test buttons. Press them all at once and its a hell of noise and staff come running....sumimasen
https://www.sau.com.au/forums/topic/355633-car-horns/#findComment-5698719
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
