  • Replies 104
27th September 2011
Car was towed to the workshop yesterday, no real progress was done, just cleaning and finishing up things that needed doing.
Called into HPIAB on my way to work today, so I could drop off some parts for the build and this is how the engine looked.
Called in on my way back also, to see how the day went, and this is what I saw...
Ahhhh, that's where it went.
Morrie had been a busy little bee today, pulled the old engine out, swapped parts from the old to the new, and even cleaned the engine bay out.
Sump is going on tonight, and should the engine should be going in the car tomorrow...not too much longer now biggrin.gif
28th September 2011
Engine is in the car, all wired up, and looking schmick. Could turn the key...but its missing oil and fuel....and still waiting on the exhaust manifold from the ceramic coaters. Once the manifold is back, on goes the turbo, and all the inter-cooler piping, etc. Then onto turning the key and the run-in process and tune...hopefully next week, it could be a anniversary of when the original engine blew up.
should be a pretty fun 300 od kw once its all done. not going e85 while your at it?
Maybe later. I feel that E85 is not suitable for running the engine in, plus I have a trip over to Victoria at the end of October for SAU Nationals, so I don't want to be dependant on E85, would like the flexibility and mileage of 98.
completely agree, also contemplated doing the trip on e85. the 400L i allowed for wouldnt be ideal
Friday 14th October 2011
Finally after 1 year and 7 Days the R33 lives again. Called into HPIAB at around 9pm on my way home from going out to tea and Morrie says "Good thing your here, my tune hasn't shown, so I am going to run your Car in"...My reaction was along the lines of BigCheesyGrin.gif
Car was put on the dyno, and run in. Lots of smoke as the residue oil was burning off from the previous engine failure, but after awhile it disappeared :)
The new engine ran like clockwork with nothing breaking or leaking. During the run in process the Turbo and Exhaust manifold hot a nice red hot glow to it :), I'll try and get a pic.
Saturday 15th October
Apparently the car was run in some more, and the timing touched up from the previous tune to coincide with the new camshafts. I don't know exact details as I was at work all day.
I had the pleasure of watching the motor being run in with the car on a chassis dyno. This motor is going to be very strong..
Here's a cool pic, a bit of heat being generated i'd say. my iPhone captured the image in infared for some reason..
Good to hear mate. So ready for a tune??
Not too sure, I know on Saturday it was having a secondary run in, and the timing was being touched up, I have heard it is going back on the rollers today (Sunday 16th), so I can't exactly say for sure.
Cheers Matt, sorry for the car's smoke trying to kill you :P
Sunday 16th October
Went to the workshop tonight to watch the final instalment of the Engine run in...was rather boring actually. After that was done we dumped the run in oil, and replaced it with some nice new fresh stuff...and then we decided to do some fun stuff...Power Runs.
Back in 2009 the boost tee was set to 14.5-15psi, and that was what it was still set too. Lets just say this was a semi bad idea, why was it bad? The amount of power that was being made was too much for the clutch to take so it slipped...or just wheel spin.
So we disconnected the boost tee and ran actuator pressure...which was just a measly 8psi. Ran the car up, no issues at all there...the power figure is about 220rwkw at 8psi with about 400nm of torque and a lot more response all over.
This thing is going to be a monster once I have a new clutch and tune in it :w00t: ...which is going to be a LONG way off :(
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
