hey do i win anything im sure i was first street tyred gtr and first timer at track
No direct prizes for that but it should put you in a good position for points in the street class when the points are released. Finish first overall (all 3 days) for the class and theres a good prize.
talk to Pez about the discs.
Send me some info on this shit box rally that you always talk about. I like shit boxes ANNDDDD Rally!!!!!!
shitboxes are awesome
the rally website will tell you all about it:
http://www.shitboxrally.com.au/
and if you're feeling generous here's the fundraising page for our team :banana:
http://www.everydayhero.com.au/von_trapp_family_shaggers
fatz you monkey. how on earth did you convince 3400 people to give you a dollar. or was it 1700 people at $2. lol.
nice one mate. I might even give you a buck to send you on your way.
any word on the shitbox you plan to run?
Hang on a sec there big boy,,,thats no shitbox,,,or are you talking about the white one parked near the kiddies playground?.
Here's a vid of me in the Handley mobile,,,no thrashing,,,just wanted to check out Jenna's rear end.
Oh isn't there a heap of room on the bonnet for some nice person to sponsor him!!!
Cheers
Neil.
Here is my session #2.
Ended early with a jammed throttle cable, managed to get it back to 2nd gear and ride the brakes the whole way in, thanks to Neil for helping me diagnose the problem.
Here's a video of a few laps in the MX5. Best time was 1:20.5 which isn't bad considering it's absolutely bone stock. You can really hear the street bridgestones complaining on some of the corners.
Nice burnout Dunc!
check it 1k worth of love
that's my old car! filename is accurate, but i'm hurt by that big sticker on the passenger door :)
still got the redtop in it? jap dash? that was a while ago now..
