Here is my 2001 R34 GTR V-spec 2.
I've owned it for about a year and a half now. Its come a long way from since i bought it back in 09. The car use to have 350kw@wheels on the standard engine with tomei turbo's, v-cam, e85 etc. As usual, the power bug bites so i decided to have a big motor built. I chose Powertune Australia to build it because of the knowlegde and tech support they give when questioned. I've been to other workshops before but they didnt provide the extra edge/support i looked for in a workshop.
Engine :
Head -
Brian Crower custom Powertune spec cams
Brian Crower springs
Brian Crower valves
Brian Crower titanium retainers
Brian Crower adjustable cam gears
Powertune ported head
Block -
Brian Crower 2.8litre billet crank
Brian Crower rods
CP Pistons
Turbo -
Precision PT7175 Turbo (975HP)
2x Tial 38mm external wastegates
Powertune Exhaust manifold
Fuel System -
Powertune twin intank fuel pump kit
I.D. 2000cc injectors
Aeromotive fuel reg
Sard fuel rail
Misc -
Tomei oil pump
High Octane extended oil sump
Earls lines and fittings
Blitz air filter
ARC air separator
Greddy aluminium radiator
Greddy aluminium pulleys
Plazmaman drag intercooler
Mine's cam cover baffles
Garage Defend cf cooling panel
Kansai front strut brace
ARP head studs
Metal head gasket
ATI Balancer
Gates Racing timing belt
Haltech platinum pro sport ecu
Splitfire coilpacks
Optima dry cell battery
Transmission :
Standard Getrag 6 Speed
Ogura Quad plate clutch
Wheels :
Track - AME Tracer (grey) 18 x 10 +15 on Mickey Thompson ET Street radials
Street - TE37 (black) 19 x 9.5 +12 on Bridgstone Potenzas
Interior / Exterior :
Nismo MFD
Nismo B-pillar garnish
Nismo oil cap
Nismo gear knob
Nismo floor mats
Nismo 320kph cluster
Nismo GT tail lights
Bodyform copied nismo side skirts
Bodyform copied nismo rear pods
More pics of the build will be uploaded in the next few days.
  • Replies 296
The car got a run-in tune on 28/2/11. Drove it around town for 1000kms which wasnt too fun being restricted to 6000rpm.
Finally got it run in and lightly tuned on 1/3/11. we had trouble keeping it strapped to the dyno under boost. but here it is for now. will be upping it again soon. currently on 35psi. we needed 3ppl sitting in the boot and 2 ppl in the the car to keep the car partially down
I drove the car to WSID on 2/3/11 the day after the 602kw tune. At the top of the track the car felt unstable at 230kph. So this morning i went to Heasman steering to get it checked out and this is how far off my wheel alignment settings were when i raced last night. Still running all the stock arms so camber still couldnt be taken out of the front or rear. but it goes straight now atleast. =)
http://www.youtube.com/watch?v=H7a2kboctz0
Powercruise 2011! 4/3/11 I drove it to the event on friday, saturday and sunday and ran around the track racing anything and everything that wanted to line up. The car has proven its reliable and able to crush v8's / tubbed / supercharged cars. Nothing broke down, nothing overheated. I was out there on nearly every chance i had. was a blast and very fun event. Not bad for a car thats just been completed. =)
awsome....any video of your beast at power cruz
What do you think those last videos were??? lol
A credit to all involved with this build, top shelf stuff!
Performed flawless all weekend, was great to watch.
Please tell me you let the capri win in the final? There was no doubt that the gtr had it the whole race, except that very slow change into third :)
That is one damm impressive beast you have there Anthony. Please please get some better photos up of the engine bay. It looks killer
lol, will do.
those last ones are all from powercruise.
thank u! lol.
yea from 2nd gear i smashed it into 5th missing 3rd. then i pulled it out of 5th and smashed it into 3rd. i had alot of airspace on him just before that happened. its all on the incar camera. hahahaha all good. was a fun event that i'd love to do again.
WOW
big dollar spend GTR, that actually geting USED.... now this is rare and nothing is blowing up either :)
i looked at the videos, "you photos needs a bit of work mate"
and thought to my self god he must be running a Dog box or something and read
Transmission :
how on earth does the standard Getrag keep up with this much POWER , "i must abuse mine a bit more now"
if you can build this car then you can get a guy to take some nice photos of that engine bay
WOW
Transmission :
lol, car isnt done yet so no use in taking high res pics.
Awesome work!! Must be a great feeling to have so much kw's rushing through the blood :) any plans for the box? Is it 3rd gear that u start to annihilate everyone or u actually get into fourth?? Lol
yea, its about 3rd gear that i start passing. nah no plans for the box just yet. i think i gotta learn how to shift into 3rd a little slower and itll be ok,
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
    • I'm interested,do you still have it?
