So tell me guys, are Skylines more plentiful in Australia, or New Zealand?
Some guy on Skylines Down Under says that Skylines are more common in New Zealand than Australia.
Now, last I heard, there were more people in either the Sydney or Melbourne metro areas than all of New Zealand, so therefore there must be more Skylines in Australia???
Oh, and another thing, why do New Zealanders always refer to Australia as "Aussie"? Thats like us referring to New Zealand as "Kiwi"... which we don't...do we?
https://www.sau.com.au/forums/topic/35645-australia-vs-new-zealand/
i reckon aus to be honest, however the R34 skyline (full range) was locally sold in NZ nissan dealers whereas the r32,r33,r34 was never sold in aus except for like 500 32 gtr's before they got banned
When you go to New Zealand you see why it seems like there are more "Skylines" there. There probably are. The thing is most of them are NA 4 door R32's used as family cars and very much not looked after. I saw very very few turbos when I was there.
Its a bit sad to see them all driving around filthy as with unappreciative drivers.
whats also funny is you notice a particular model is that you see more of the non turbo vs the turbo model, look at the silva or 180sx, have ever seen the turbo version of it, more often that not you see the turbo charge model. where as with the r33 you more than likely see a gtst all the time
wierd
No statistics, but I'm an ex-pat kiwi (ex-nz, now ex-nz ex-oz - it's getting confusing!), and have family in nz. As such, I've travelled back and forth from oz to nz (and now japan to nz/oz) over the years, that I've been able to watch the import market expand there.
Personal observations:
* there are more skylines in australia
* there are more skylines per capita in NZ
I have very fond memories of being in NZ in the early 90s and seeing my first GTiRs, GTRs, etc - it had a great affect on a teenage mind.
Ok bein' a kiwi and all, thought I'd do a traffic count on the way home from work tonight.
I work in the CBD of Auckland which has just on 1 million people (about the same population as Hawthorne?) :D
On the 35km drive home from the CBD to my rural home, I saw 12 Skylines and 1 Stagea. 3 were R33, the rest R32.
On my last business trip to Melbourne (March 2003) I saw 3 or 4 Skylines during the whole 3 days (I was in the CBD only...) I'm sure there are heaps more than that around.
The other thing to take into consideration is that we have had high volumes of imports for quite a few years so there is many different flavours of Japanese performance cars around. Once upon a time every second car was a Legacy with a BOV, then it was WRXs, GSRs etc.
Cheers,
G
that's right, the other thing you'll find in NZ, as graeme mentions, is a host of very boring japanese cars that people (usually) don't bother to import to australia - sunnys, bottom-spec skylines, currens, cavaliers, laurels, carinas etc etc etc. A lot of these cars, versions mostly from the 80s and early 90s, are becoming very uncommon in japan - because most have already been 'cubed' or dumped on other countries.
    • looking for some help and maybe some insight on others experience with a new LSD. R34 GT ran and drove beautifully, but always alot of grip loss due to the open R200 rear end, so I just installed a new 1.5 LSD way into the stock open R200 for a ER34. Simple. Everything seemed right. I test drove for the first time this weekend. as I started to back out the garage the first time slowly with tires straight it sounded and felt like I had a loose or half disconnected drive shaft...that was clucking around loose and shaking entire vehicle, and making it feel like the trans clutch was spontaneously slipping then grabbing very roughly while just letting out pedal slowly. I backed it out went to pull forward with the same noise, shake and slip grab feeling with hesitation, I turned the tires to back out more and then pulled ahead some same thing but worst because of added wheel resistance (which that I expected) puzzled … pulling it back in checking everything over and finding nothing wrong, I tried it the next day. same thing, couldn’t believe how it shook everything again making a terrible noise and making it feel like the trans clutch was slipping and grabbing, but I got it out of garage into the driveway, got it straight, drove forward and then reveres a few times in a straight line everything shaking , causing what felt like clutch slip and grab every time, sounded like right behind front driver tire and I could feel it in the floor board with my feet,... worst right when beginning to let clutch pedal out to engage slightly, shuttering and sounding terrible along the way…I managed to slowly get down the road, babying it the whole way, once I was rolling (out of 1st) seemed to be better and between shifts, then clutch felt closer to normal…not slip/ grab etc., but back down to any stop, straight road or turning, same thing. Made no difference if all tires were straight or if I was turning. All other gauge read out correct. with in 2 miles as planned I reached the empty parking lot and performed the break in procedure that came with lsd, essentially to drive in a figure 8 a bunch.  Did this, binding chattering, and shaking the car the whole way. I drove it back home seemed somewhat normal once I was in straight line and past 10 mph or so, and I know it will “bind” on corners and cause some tires squeal when turning especially from a stop, but when I begin to move it still causes what feels like the trans clutch to slip and jerk badly as well as shaking the entire car, and sounds terrible, that I didn’t expect. I used the fluid they supplied with LSD kit and did the breaking, planning to change fluid as they suggest after breaking, but wondering will it get smoother or less aggressive with use? maybe a 1.5 is just too aggressive for normal road driving?   I have a LSD that I put in my 71 cuda when I restored it, with amazing smooth , quite yet effective results. Different style LSD but that ones a joy to drive. maybe expecting too much from this R200?
    • Join SAU NSW for a flame-grilled feed & flame-spitting cruise! Sunday 17th August 2025 3:30PM Meeting Archies Flame Grille Sylvania Waters 4:45PM Cruise Departure 5:15PM Arrival at Cape Solander Kurnell Meet Location: Archies Flame Grille Final Destination: Cape Solander Kurnell *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
