  • Replies 390
Posted Images
yep makes sense
the guy i work for during uni holidays runs 3 cars in teh AMCA series (like super sedans - Holden 253 v8's on HZ front ends with custum body's)
1 is running methanol and he was saying that it runs a 14:1 comp ratio, whereas the other two are running PULP and are only at 11:1
methanol is a cooler burn allowing a higher comp ratio to make more power (but requiring 3 times the amount of fuel, and massive big fuel lines - try thicker than your thumb, internal diameter about the thickness of your pinky finger!!!)
thats interesting that in that short amount of time it gets to 92 deg
im trying to understand how you run it - is there a radiator at all? or an overflow type bottle with a high pressure radiator cap to increase the boiling point of the water?
Thanks for the replys.
No radiator, the copper head gaskets do not have water jackets. So the heads are just filled with water and connected to a overflow tank to allow for expansion.
Well after alot of work over the last few weeks today it all came together, but unfortunately we will not be racing at jamboree. The block we prepped and filled actually has a massive crack between cylinders 4 and 6 where the drivers side bank meets the valley. This is were the problem originated, unfortunately it was not picked up in testing, it appears that the head stud has tried to pull that section of the block away from the rest of it. Grout filling will hopefully stop this on the next engine. Fortunately i have another block, so it will be prepped and o'ringed and we'll begin changing everything over. Were also going to redesign the supercharger drive system to put less stress on the front of the crank. So we will now be aiming to race at street car shootout in about a months time i think... not sure on exact dates.
ROFL!! haha cheers mate.
Well we tryed fevourishly to weld and devcon the block up just so i could get a run at jambo, but it was cracked in a few more places then we would see without pulling it out of the car and stripping it, luckily due to rain we wouldnt have been able to get a run anyway. the spare block is being cleaned and crack tested this week, then will be sent to have the deck surfaced and o'ring grooves machined. Then it will be simply a case of changing everything over...
  • 2 months later...
Well its been a while, but the car is back together and seems to be running well.. we will be heading out to willowbank tonight for some testing before jamboree this weekend. Ill keep you all posted..
well unfortunately willowbank couldnt get an ambulance on standby so the test n tune was cancelled, so its out to jamboree tomorrow to see what she'll do.... should be interesting
i want a text tomorrow saying "f**ken aye giggidy 9 second pass"
Well MISH!!! convertor came back wrong... its only flaring to 3000 so it bogged terribly off the line managed an 11.6 before giving up... then when putting it back in the trailer we noticed some sort of death rattle comin from somewhere... havent had time to look at it yet....
Somebody say big block chev??
Well still havent looked at it yet, but if it is the engine we will be going with a NA injected 454 simply for simplicity and reliabilty.
Its sad it cant stay nissan but its simply not viable to continue the nissan route on my budget, i think what i have acheived on a virtually standard internals engine is only testiment to how good these engines are, perhaps in the future when money is less of a problem i will continue the R n D with the VH.
Thats a very interesting suggestion u have there....
full of bright ideas dude! put the biggest farken nozzle you got.
shame that it's being such a mish... was so promising!!! any idea what the death rattle is? something loose in the cylinder? :)
    • If they can dyno them, get them dyno'd, make sure they're not leaking, and if they look okay on the dyno and are performing relatively well, put them in the car.   If they're leaking oil etc, and you feel so inclined, open them up yourself and see what you can do to fix it. The main thing you're trying to do is replace the parts that perish, like seals. You're not attempting to change the valving. You might even be able to find somewhere that has the Tein parts/rebuild kit if you dig hard.
    • Can you also make sure the invoices on the box (And none exist in the boxes) are below our import duty limits... I jest, there's nothing I need to actually purchase and order in. (Unless you can find me a rear diff carrier, brand new, for stupidly cheap, that is for a Toyota Landcruiser, HZJ105R GXL, 2000 year model...)
    • Murphy strikes again! Nothing at all would have gone wrong if you had the tool kit in the car! You'd have just found the clamp loose the next time you went to touch it...
    • I have been being VERY quiet about what you're alluding to, as it is something that ticks me off... The number of cars from factory that run coil overs is HUGE! Most of them these days do... The other part that annoys me, is people saying "Well all the incabin adjustable suspension is illegal by blah blah blah"... If that's the case, then why can I buy a car brand new that can do it if, FULL STOP in cabin adjustable suspension is illegal...   Also, I could just chuck some aftermarket shocks in my car, throw the stock springs on, after my blue slip, dump my super low springs back in. Same shock and spring style setup... Hell, they could also be the same colour springs etc.     I'm voting, BlueSlipper didn't want to touch the above car for some reason. Whether it be some sort of bias against the car, the owner, them maybe having previously done dodgy shit and now they're being super careful in case they get slapped in the face by the Gumbyment again... Find a new blueslip place.   And can confirm as you had said, yes there are holy bibles of vehicle heights, and all sorts of other suspension stuff. Heck your run of the mill mechanic, and tyre shop has access to all of that stuff. It's how they do wheel alignments...
    • Funny story Heading to Sydney this morning on the HWY there was some slow traffic, so I gave it the beans and midway through my overtaking "power run" I lost all power It seems that I missed a hose clamp,  and the MAF and filter went WiFi To make this more problematic, the little tool kit that lives in the boot, is sitting in the sun room at Goulburn......LOL Luckily for me I found a bit of steel on the side of the road that could be used like a rusty and bent flat head screw driver to tighten it up enough that it got me into Sydney, it is now all tight like a tiger with the aid of a 8mm socket Note to self: Use my brain and double check stuff, and always keep that little tool kit in the car for when I have a brain fart
