where have people mounted gauges ???
What gauges?
I have
* boost gauge sitting just above the dash vent on the drivers side next to the A pillar.
* Exhaust temp gauge sitting to the right of the stereo just in front of the cigarette lighter. (made a custom mount from a piece of PVC tube)
* Greddy Informeter to the left of the main dash.
Can post a pic if you would like.
Cheers
Andy
Pretty much anywhere they can be seen from the driver's seat, lol. You'll find the fav spots are prob A pillar & inside the flip up (top) section above glove box. A lot of M35 owners are running GReddy Informeter touch which has configurable display so you don't need much else. Can mount this anywhere really. Mine is clipped onto a vent (use mobile phone holder) so can be removed easily.
Cheers, Leon.
What gauges?
I have
Cheers
Andy
Hey Andy, I'd be interested in seeing your custom EGT gauge.
Here you go Leon.
I just cut a 25mm wide section of 50mm PVC tube. It is really easy to manipulate with the heat guns. I used the actual gauge to push into the soft plastic and used a piece of wire on either end looped through the gaps to pull it around the gauge and then cooled with some water. Then flattened the other side. Paint black and done. :)
Hey Leon, how does that mobile phone holder work out?
Not too bad since being able to return my car (interior mainly) to stock without leaving too many remnants of my work is high on my list of priorities. The holder was the slimmest one I could find that would expand to the width of the GReddy unit.
I tried it on the drivers side first but not quite enogh room between dash cowling & raised centre. I laid some felt (or similar) inside the metal clips which slide over the vent slats so it wouldn't scratch them (anal, I know) and I had to use a small piece of black rubber to wedge the vent so it would stay put over bumps. It can't be seen & it stops the vent moving down from the weight hanging off it :happy: . Also, it is easy to slide out & put in the cubby below, to hide it from prying eyes if I am ever in a dodgy location like Sydney lol.
Andy, good work on the gauge holder you fashioned. That's a nice spot for it too. I hadn't worked out a way of mounting anything there successfully, so well done :thumbsup: .
What gauges?
I have
Cheers
Andy
yeah thats a good one might try that...... dont want to screw anything into the dash tho, so double sided tape it'll be!
just got a boost guage myself........ on idle its on 18 In. Hg (VAC) and in gear its 15 In. Hg (VAC) but on power it spikes to 18PSI and levels out to 15PSI is this correct ???
Edited by WAGON_BOY
Sounds a little high. Stock boost should be around 14-15psi on your Axis.
You have changed the dump pipe and done the exhaust?
Cheer
Andy
Cheer
Andy
ive done the dump pipe but the rest is getting replaced on friday......... i was reading i would get an overboosting issue after replacing the exhaust thats why i wanted to get the comparision before and after.
your referring to me,
I was only over boosting as i didnt enlarge the wastegate when I went to Stage 2 Sierra build on the turbo.. you shouldnt have any problems with your turbo..
ill be getting mine fixed this week sometime when I can be stuffed.
no worries :)
so why would i be sitting on 15PSI then???
do i need to go an buy a boost controller ??? :(
anyways ill put up pic's later of the new system :)
no worries :)
I think there's some variation in factory boost levels, eg my RS should "only" run at 12psi (or 12.6 to be exact) according to most sources, but my Pricol gauge had it at 14.x psi (dropping off to 13psi just before a gear change) on the stock exhaust. Now with full turbo back system it occasionally runs of the scale (15psi gauge only).
A typical boost controller won't let you run lower boost than standard. I think you will have to play with wastegate actuator springs or the like, to achieve that.
    • That sounds like an excellent idea. But total self-sufficiency means exactly that. You have no-one else to blame when your system faults out and you have no power for a week or two while it gets fixed. You'd have to go the whole hog and get a diesel genny and all the switchover gear, to get you through such times. And, despite the fact that over 20 years, my system has been pretty reliable**, I have seen so many inverter explosions (or less dramatic deaths), panel and roof JB fires, and so on, over that time, to know that the stuff is the same as any other bulk Chinese manufactured stuff. The failure rate is well above zero - both on the equipment and on behalf of the meth addled installation labour force. And then..... warranty and means of redress against the supplier you bought the gear from. Best I can tell is that only a handful of solar companies are still around within 5 years of starting their advertising pitch. They disappear and phoenix like crazy. So, as per 1st paragraph, I suspect the only way to is go balls deep and spend maybe 2-3 times as much as you might think, so that you have every base covered. Plus, know and understand your gear intimately, so you can diagnose problems, sort them out yourself, etc, etc. Plus, probably have to consider upgrading various parts as the years pass, to maintain compatibility with newer stuff, performance and reliability, etc, etc. Whereas, remaining attached to the grid has an ongoing cost that keeps going up even if you use bugger all power from it. But it does provide the fallback in case of the worst case with your own gear. You either pay up front or as you go, I suspect.
    • Add more solar panels to the array. Call the electricity company and tell them you're moving out... Live off grid electric wise
    • Hi Jasmine. How's the war going?
    • I'm extremely suspicious of the VPP stuff. Best I can tell, you surrender any and all control of your panels and battery to the VPP, because there's no way that anyone could write a sufficiently useful set of "rules" as to how much you would be willing to let out of your export meter at any given time. If one of your main interests is to have enough in your battery every evening to get you through the night without having to import, you could easily find yourself with nothing in your battery at the end of the day, or part way through the night, and then be paying import pricing instead of paying nothing. I cannot see how this cannot come to pass.
    • majority aftermarket is an10 yes, but majority of OEM is An12 r35 OEM cooler lines at close to an 12, the hard line that car uses is almost 20mm  Porsche OEM is also AN12   i figure, if our power levels are close to 1000hp, then AN12 should be a must if many OEM standard power vehicles use AN12
