where have people mounted gauges ???
What gauges?
I have
* boost gauge sitting just above the dash vent on the drivers side next to the A pillar.
* Exhaust temp gauge sitting to the right of the stereo just in front of the cigarette lighter. (made a custom mount from a piece of PVC tube)
* Greddy Informeter to the left of the main dash.
Can post a pic if you would like.
Cheers
Andy
Pretty much anywhere they can be seen from the driver's seat, lol. You'll find the fav spots are prob A pillar & inside the flip up (top) section above glove box. A lot of M35 owners are running GReddy Informeter touch which has configurable display so you don't need much else. Can mount this anywhere really. Mine is clipped onto a vent (use mobile phone holder) so can be removed easily.
Cheers, Leon.
What gauges?
I have
Cheers
Andy
Hey Andy, I'd be interested in seeing your custom EGT gauge.
Here you go Leon.
I just cut a 25mm wide section of 50mm PVC tube. It is really easy to manipulate with the heat guns. I used the actual gauge to push into the soft plastic and used a piece of wire on either end looped through the gaps to pull it around the gauge and then cooled with some water. Then flattened the other side. Paint black and done. :)
Hey Leon, how does that mobile phone holder work out?
Not too bad since being able to return my car (interior mainly) to stock without leaving too many remnants of my work is high on my list of priorities. The holder was the slimmest one I could find that would expand to the width of the GReddy unit.
I tried it on the drivers side first but not quite enogh room between dash cowling & raised centre. I laid some felt (or similar) inside the metal clips which slide over the vent slats so it wouldn't scratch them (anal, I know) and I had to use a small piece of black rubber to wedge the vent so it would stay put over bumps. It can't be seen & it stops the vent moving down from the weight hanging off it :happy: . Also, it is easy to slide out & put in the cubby below, to hide it from prying eyes if I am ever in a dodgy location like Sydney lol.
Andy, good work on the gauge holder you fashioned. That's a nice spot for it too. I hadn't worked out a way of mounting anything there successfully, so well done :thumbsup: .
What gauges?
I have
Cheers
Andy
yeah thats a good one might try that...... dont want to screw anything into the dash tho, so double sided tape it'll be!
just got a boost guage myself........ on idle its on 18 In. Hg (VAC) and in gear its 15 In. Hg (VAC) but on power it spikes to 18PSI and levels out to 15PSI is this correct ???
Edited by WAGON_BOY
Sounds a little high. Stock boost should be around 14-15psi on your Axis.
You have changed the dump pipe and done the exhaust?
Cheer
Andy
Cheer
Andy
ive done the dump pipe but the rest is getting replaced on friday......... i was reading i would get an overboosting issue after replacing the exhaust thats why i wanted to get the comparision before and after.
your referring to me,
I was only over boosting as i didnt enlarge the wastegate when I went to Stage 2 Sierra build on the turbo.. you shouldnt have any problems with your turbo..
ill be getting mine fixed this week sometime when I can be stuffed.
no worries :)
so why would i be sitting on 15PSI then???
do i need to go an buy a boost controller ??? :(
anyways ill put up pic's later of the new system :)
no worries :)
I think there's some variation in factory boost levels, eg my RS should "only" run at 12psi (or 12.6 to be exact) according to most sources, but my Pricol gauge had it at 14.x psi (dropping off to 13psi just before a gear change) on the stock exhaust. Now with full turbo back system it occasionally runs of the scale (15psi gauge only).
A typical boost controller won't let you run lower boost than standard. I think you will have to play with wastegate actuator springs or the like, to achieve that.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
