Nice Theo.
Glad you find it nice and smooth to drive. You'll have some fun at the drags I think. A programmable boost controller will take care of that drop off. Does the ECU have that function?
Are you still running off the AFM sensor? What Volts did you get up to?
Did you get a chance to over lay with my 3rd gear pull?
I'm curious about the AFM voltage also. Mine has peaked at 5.00v on the Informeter, so I wouldn't expect you'd go much higher than that.
No one wants to know about your 3rd gear pull Alex. :yucky:
I've seen your cars get up to 5.12v or maybe a bit higher
Can't remember whose pipe it was, but I was flogging it.
We all know I pull hard, Dale....
:P
FYP.
Was that with one of Scotty's suction pipes?
I don't think my version; being (16ish% smaller cross sectional area) will actually get there.
Edited by Daleo
farkin lol.
Ummm, I know Leons was up over 5 (5.02), as was Craigs(5.12) -both of them have intakes. Rudis was up there too(4.83), but didn't have an intake.
Another car with a highflow went 4.88v with no intake
I suspect 5.12 is the limit - I saw it maxed from 5800-6800rpm on Craigs on the nismo ECU. Obviously each sensor will have a discrepancy. I also think that each progression of the ECUs have different cut off points.
Now I'm lucky to see much over 4v... but thats with the upgraded MAF tuned in.
Nice Theo.
yeah still running the stock AFM, not sure of the voltage u'd have to ask.......
we did an overlay but because of the different diff ratio they where to different to match up.
i cant quiet make an accurate response on it yet but the gearbox is quiet different, like it still seems to shift quickly but it doesnt have the harshness like it used to so i dont know if its the same or slower................... my thoughts are if its softer its slower but i could be wrong. and we played with the gearbox settings on the ECU but couldn't really determine anything LOL
The timing drop between gears definitely works, it is just too late for the shift, as in it drops the timing after the gearbox has changed. It makes for a weird power drop after the shift. We zeroed it all out in the end. It is understandable when you think about it, as the Fcon has no idea what the gearbox is doing, so it must work off the revs dropping or something.
I changed to the Nulon fluid in mine, dropping the dextron III that Kewish put in there after the build. Surprising how much firmer it shifts, perhaps the Nulon is thinner filling the accumulators quicker? It positively thumps into second and third now causing all wheel chirps. :)
Less than a tenth separates the four runs! Congrats, very consistent Theo.
Did you try to vary anything to get a different (better) result? Were you able to get wheel spin at the start line or too grippy?
  • 3 weeks later...
finally took the car down to pedders for a check over here's the list:
Front lower control arm & Inner bush - rear bush splitting.
Inner tie rod end - RHS has free play.
Steering rack - mounts are worn.
Front swaybar links - LHS has free play.
Rear X member mounts - both fronts are soft.
time to give Craig and Dale some work LOL
  • 4 weeks later...
i'm still getting fault lights and havent been back to get it fixed, apparently he's booked out for 4 weeks in advance. dont want to blow the motor,
i'll probly come down for a little bit but yeah i wanna see some of bathurst and i have some work to do in the arvo aswell, bloody cashies LOL
also i need a fair few bushes replaced aswell after last texi still havent got round to it been way to busy!!!
OK any of the guys running F-Con's might be able to help me out and of course Scotty...........
i might aswell quote whats been said its a it easier, but any ways Alex did a cipher log on my car and then i passed on the details to Jez and the question is as follows:
Alex: "there seems to be a problem with the ECUs AFR correction, because it is cycling to each end of the ability to % correct. To my knowledge this is usually caused by the fueling map not being accurate enough in the low range/stoich range. You can try disconnecting the O2 sensor, and see how it drives, but let Jez know, and I'm sure he'll be able to touch it up a bit. If it gets really bad, just disconnect the HKS and run the stock ecu."
Jez: "Have u spoken to Scott? He mentioned that the f con is designed for 350z and the 02 sensors cant be used accurately or something along those lines. Have a chat to him but of course we can check it on the dyno or road with my wideband"
cheers Theo.
we done a data log and it got up to 4.8Volts could still go higher i guess didnt push it to hard.
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four-speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to its full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so stupid hot in there, that made it all the more easy -after I was standing there looking at the car and said 'f**k it'- to finally remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
    • Thanks for that, hadn’t used my brain enough to think about that.
    • Also playing with fire if they start to flow more air down low than what the stock twins can. It's not even up top you need to worry, it can be at 3000rpm and part throttle and it's getting way more flow than it should.
    • Any G40/1000 or G40/1250 results out there?
    • You still want a proper tune on the stock ECU though. Stock tune + stock ECU with GT-SS/-9s is probably playing with fire if you're running more than stock airflow/power.
