here's what your been waiting for some pic's...............
relocated the horns to the otherside to make room for my powersteering cooler.
and managed to fit a new tranny cooler with fan infront of the passengers side wheel.
it was a C*** of a job but took it for a test drive and no leaks, so now just gotta button up some bits and pieces and wire up the fan :)
post-83704-0-11732000-1353724357_thumb.jpg post-83704-0-14935500-1353724383_thumb.jpg
had fun at sydney motorsport park on saturday............ go pro footage still to come. managed a best time of 1:14.77 with overheating brakes and motor temp spike!!! got to hot so i called it a day and wet and jumped in a cold swimming pool instead.
Is that video on slow mo? Either that or you're being very cautious?
It's wet nummers....his in a 2t wagon with sort of shit tyres on a track that has not been rained on in weeks. There's a reason your kind always crash isn't there!
see me entering into turn 1 for the very first time (between the small straight and into the long straight over the hill)........ wet track pretty much no throttle just enough to keep the speed at 80km/h and see how much the car got sideways, it was slippery. even in the dry i could only take that corner at about 100km/h and the car still got squiggly.
like Criag said of course im going to be cautious first time on the track, first time on the course in my only car be it i dont use it dayly but still.
wait till i get the other vids up, this wasnt timed, but the next session that was and i got a 1:20 lap and then once it was fully dry i got a 1:15 and later in the day before it got to hot i got a 1:14 so i'm quite happy with it, it's no track car by anymeans but it was a load of FUN.
if i wanted a circuit car i'd go buy a S8 RX7 and build that up.........................
  • Like 1
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
