finally after getting the wrong coloured facia its all back together and I have a radio again!!!
I've put up a thread with the wiring colour codes in case anyone else needs to replace theirs, cant seem to link if for some reason though.....
Http://www.skylinesaustralia.com.forums/topic/437160-m35mradio-replacement-wiring-colour-codes/
Finally got my go-pro footage from the SAU track day back on the 29th of Oct 2013 @ SMSP south circuit.
here was my last run where I got a free run with no traffic and managed 3 awesome laps
2x 1:09's and a 1:10.
http://www.youtube.com/watch?v=dcvL4eyt1qY
best of the day was a 1:09.14 with consistent 1:09's all day long :)
starting to get p*ssed off with all the little niggly bits, so I'm going to try and sort them out before I loos my sh*t:
1) redo my headlights
2) need to get the bonnet struts as the fibreglass bonnet is to flimsy to support by the stock arm and so the AXIS bonnet add on is starting to fall off.
3) this radio change over has been a massive PITA, hate the aftermarket A/C buttons, and seems as though I've blown part of the BCM that controls interior lights, tail lights and parker lights so now I need to replace the BCM which seems more or a PITA than it should be.
4) need to tidy up my gauges as it looks like sh*t so going to have to pull my finger out and make a fibreglass one!!!
5) should probably replace my drive belts and fuel filter I'm guessing they are well over due!!!
6) need to get this window washer bottle cos its a PITA having a dirty window all the time that I cant clean whilst I'm out
once all this is done I might feel better cos atm I'm getting annoyed my cars turning to sh*t because of neglect!!!
ah well that's my rant for the week!!! :)
I still have no 6 in pieces. :domokun:
I'll get cracking.
You makin a washer bottle Dale?
I did a cardboard mock up about a billion years ago for Theo; will use the OEM filler neck, and the side also acts an air guide for his oil cooler.
I have all the sheet guillotined and bent, neck made, then we had another kid. :rolleyes: I need to machine some bosses for the pumps to push through then get off my arse & weld it.
I'm so busy at work now, I barely get time to do my paperwork in the extra hour I work on top of my 12hr shift. Weekends used to be fab time; not anymore.
It might hold a litre of water, with the neck volume added; a little more.
It's something I was interested to make for myself, sounds way too complicated to make multiples of though.
I would love to get a second oil cooler in there... Not like you need 40L of washer fluid anyway. :P
I have the advantage of being able to use my cardboard mock up for templates; I'll see what this one turns out like.
A litre odd would last long enough.
    • No, you're wrong, and you've always been wrong about this. The Nismo has 2 sets of openings. One is a real 2-way, and the other is a 1-way. There is no 1.5-way possible with the ramps that they offer. A real 1.5-way does exist. That Cusco stuff I posted is a prime example. If the forward drive ramps are, say 55°, and the overrun ramps are, say, 30°, then you will get about half as much LSD effect on overrun than you do on drive. It is real, it realy works. OK, you're slightly right. The Nismo has 55° and 45° ramps on the 2-way, so it does offer less LSD effect on overrun. But, I think that just means that they've (probably) sensibly established that you do not want actually equal LSD effect on overrun. You just want "quite a lot, but not quite as much as the drive LSD effect".
    • Just wanted to unearth this and post my baby with the new front ❤️😝 Took her to my wedding rehearsal today. Next up is getting wide skirts (after wedding)
    • Yea, that is what I was getting at in my ramblings too. The nismo one actually is a 1.5 way and a 1 way. They don't do a *2* way because a true *2* way would have equal ramp angles. Or is that a true 1.5 way? Realistically I think a "1.5 way" does not actually exist. A diff can either lock in two directions or one. It also doesn't help that a LOT of people in Australia speak about 1.5 way diffs are referring to their 1 way diff.
    • Well, the trouble with that ^^ is: The configuration shown is absolutely a 1-way, not a 1.5-way. There is no way that a 1.5-way can be said to offer LSD action only on acceleration. If Nismo cannot get that right, then it is impossible to believe their documentation. That ^ is not a 1.5 way setup. That is a 1-way.   And so now I have allowed all doubts to flourish and have gone back to look at the MotoIQ video. I originally made the mistake of believing him when he said "this is a 1.5-way" at the ~6:10 mark. Because what he did was take the gear assembly out of the 2-way opening and just rotate it one place to the left to drop it into the 1-way opening. When he dropped it in there, the cam was "backwards" compared to the correct orientation shown in all other photos of that config. The flat shold have been facing the 1° ramp side of the opening, not the 55° ramp side. And I thought, "gee that's cute", but I was concerned at the time, when he put the other ring back on, that the gap between the rings looked like it was wider then in the 2-way config. And then I said a lot of things in my long post on Tuesday that could only make sense if the guy from MotoIQ was correct about what he'd done. BUT... I have now done my homework. I grabbed a frame of the video with the 2-way config, and then grabbed another with the "1.5-way" config, snipped out the cam and opening of that frame and just pasted it direct on top of the 2-way config. I scaled it so that the triangular opening was almost exactly the same height in both. AND.... the gap between the plates is wider with the cam installed in the triangualr opening backwards. That is.... it cannot go together that way. There would be massive force on the plates all the time, if you could even reassemble it.  So, My statement on the matter? The Nismo diff is actually only a 2-way and 1-way. There is no 1.5-way option in it, regardless of what they say. Here's a photo of a real 1.5-way ramp opening from Cusco (along with the 1 way option). And the full set of 1 through 2 way options from their racing diff, which is not same-same as what we'd typically be using, but...the cams work the same. A little blurry, but it comes from this Cusco doc, which is quite helpful. AND.... Cusco do in fact do what I suggested would be sensible, which is to have rings that do 1 and 1.5, and 1.5 and 2. Separately.
