i havnt had an engine light on the F-CON since i cleared up my water damage in my harness.
clear dash except the airbag one :verymad:
No engine light since resetting mine, I have done over 1000ks now. :)
thanks for the offer Russell but I'll see how it goes for now haven't had any drama's yet and I've put my old afm back in.
the problem with Scotty's afm is I'll need to get a retune anyways :( or put a resistor on it to get the correct values like the stock one.
Why haven't you gone to a MAP sensor tune yet?
  • 2 months later...
on the upside of my RX7 woes I think I've blown the front drivers side wheel bearing on the Stagea again LOL
haven't even bothered with my F-Con problems either :(
  • 4 weeks later...
well I had a metal to metal scraping noise coming from the passengers side front wheel checked the brake out a few times and didn't seem to be rubbing so I replaced the wheel bearing only to find the noise was still there afterwards......... hhmmm wonder if its a CV ??? :(
  • 1 month later...
Okay i have a strange metal on metal scrapping noise its been driving me mad for a few months coming from the front passengers side.
firstly it does it mainly when coasting along as soon as you hit the throttle even a little bit it stops, and doesnt really make a difference if its loaded or unloaded.
so far I've checked the brakes, even went as far as pulling them off to inspect them. (sounded like a stone could've been stuck in it but wasn't) BTW i checked this multipul times.
then i bit the bullet and replaced the wheel bearing as its probably copped a hiding especially on the ripple strips at the track but the noise was still there.
next i thought I'd get the disc machined just in case, no difference.
still looking i thought the only other thing it could be would be the CV / drive shaft so i replaced that as well with no avail.
got to thinking maybe the front diff was on the way out and transmitting the noise out onto the wheel so i drained the fluid and everything looked pretty typical no major metal fillings and the fluid looked pretty clean.
so just incase its got anything to do with the gearbox I'm currently replacing the fluid in that as well ( doesn't go astray as its probably been 4 years since it was changed and i mainly drive in manual mode)
now I'm out of idea's and its driving me mad!!!
maybe the new wheel bearing was pressed in badly i dunno but it made the same sound minutes after it was changed from the old one.......
please i need your help before i go nuts!!!
You tried putting it up on stands and hunting out where the noise is coming from?
My first thoughts was disc rubbing on stone shield or even the bottom hub alloy thing.
I know my GTR discs rubbed on them before I adjusted them...
  • 7 months later...
It's been ages since I've posted here just over 110,000km and still going strong!!!
only thing that needs doing atm is regas the rear struts for the tailgate, it's one of those things PITA to organize and have time to get it done HAHA or I'm just to lazy and have better things to do with my spare time
  • 1 year later...
  • 2 years later...
  • 3 months later...
Its a SAD day, the Stagea went to its new home Yesterday, I hope the new owner loves it and looks after it as much as i have......
I know I'm  pretty much the last of the originals so if anyone's left and reading this i thank you all for the journey its been great!!!
This isn't the end for me, i love this club and will continue to be a part of the regular SAUNSW events etc.
Peace, Lambchops!!!
  • Like 1
Peace, Lambchops!!!
Hope its gone to a good home!
  • Thanks 1
  • 1 year later...
    • One thing I can tell you is, do it properly the first time. If you encounter unexpected problems just let the car sit for a week or two if you have to get some other parts or figure stuff out.  I'd have said go and use as many OEM parts as possible but since you want to change the turbo later on a custom kit is probably the better choice. Since I have no experience with RB25 just compare parts diagrams and images before buying a line kit and it should be easy to see if it has everything you need. Amayama has very good parts diagrams and part number lists, that is what I used a bunch to figure out what I might need. And don't forget to plan ahead and possibly renew other stuff that's easy to get to while you're in there doing the turbo lines. Happy wrenching
    • Update 4:   Hi all, good news. Engine is running and all the gaskets and seals seem to be working as intended. No leaks so far, even the JB Weld seems to hold. I flushed out the old coolant a few times and put in fresh coolant, not Nissan stuff, I decided to try the Ravenol Protect FL22, they claim it works for a wide variety of JDM cars and the opinions on it by some people were pretty good. And it has the nice poison green color! And man am I glad I bought a coolant system tester earlier this year, vacuum filling works wonders on this engine. I can definitely recommend this to anyone still doing it the old school way. All you need is compressed air supply. Will have to do a small test drive as soon as I can, I removed the gauge cluster again as the tacho needle was still bouncing around a bit but it was much better than before already.  I also found some cracks on all 4 tires inner and outer sidewalls. Apparently these tires should 't be parked on for extended periods or be kept under 0 degrees during storage, which I did not know. Clearly the previous owner didn't look into those details either, he probably bought them just cause they are cool semi-slicks. I'm just wondering how tf I am supposed to reach 30-80 degree tire temperatures on the public road consistenly, these tires were never going to work for my use case. I'll probably order Continental SportContact7 ones as these are the best allround summer tire available right now and I don't think I'll need anything crazier for now. Do let me know if you have experience with various tires and which ones you recommend.
    • You have no idea how many goddamn boxes I received these past three months haha Most have been put to use by now though, luckily
    • Not going to pretend I didn't do a bit of junky work this time around, but mostly due to the fact that some things I am not willing to spend days fixing right now, like wiring. I try to do most things properly the first time around.
    • Regardless of neglect or incompetence, fixing either is tedious and annoying. Most of the neglect on my car is definitely rust. I hope I can at least pass inspections later on and they won't fail the car due to slightly corroded hardlines. I was generous with rust converter and wax and it looks ok, most lines in the rear are hard to see properly anyways.  Definitely will test them though to make sure they don't rupture under pressure, in that case the car isn't going anywhere this year.
