  • Replies 67
ok, guys it seems that there is more than enough interest for the lips. I am jsut sourcing a series 3 lip that is in good condition and i havnt forgotten about you prank.
If anybody would like to beat me to the punch and has a series 3 lip in good condition then let me know as the lucky person will get theirs for free!
I just had a very good email requesting the price of the carbon fibre lips.
In the original post I wrote that the lips would be $150 ea or $100 for 5 or more.
This price was for the fibre glass ones only
However the carbon fibre ones would be around twice the price. After checking the cost of materials The cost has been finalized to $300 each and $250 for 5 or more!
If anyone has any issues please contact me one way or another.
My appolagies if anyone has been mislead!
BJ,
As I understand it, if we have an order of 5 or more combined the Lips would cost...
$100 for Fibre Glass
$250 for Carbon Fibre
If that's the case... that's a very cheap price compared to UAS lip that sell the FB for $395 Can you please confirm.
YES, Mesh confirmed. as i said i am sorry to let anyone down, it is not my intention to mislead anyone. I re - read the post and realized that i had made a blunder. I know its not difficult to read but i became a bit careless with the details of the buy and focused on the posting rules so i didnt have to repost and loose momentum with the interest.
I think its a reasonable deal for you guys and you may too if you do a little research yourself. I'm not offering a charity, I'm in it to make a profit and you guys should be in it to take advantage of the services i can offer.
Let me break it down to you
Material costs $47.65 per square metre (carbon fibre) - full sq mtr used for 1 lip
resin costs $5.00
mould release wax $1.00
clean rags, paint brusshes etc small costs $6.00
about 6 hours to make one, about $15.00 per hour - not included in cost
Clear paint $60 per litre - 250 ml used per lip
Spray painter to paint, block and polish 6 coats, and polish between every two coats to give a superior product. $100
so the total is now mmm let me do it for you, cost for a carbon fibre lip is $174.65
so for 6 hours work and some orgaisational work i get 75.35 that gives me $12.55 per hour. do you work for less than $15.00 per hour?
I dont know what you guys do for a job, but working in the race car industry, makes you a perfectionist. I too have a nice car and help with advice where ever i can to those without much knowledge. I am not a businessman here trying to make a fast buck and I dont make crap products!!!!!!
$250 sounds reasonable to me.
how much more is the carbon kevlar?
i'm assuming the carbon fibre will shatter fairly easily when coming in contact with kerbs... is the carbon kevlar much stronger?
$250 sounds more reasonable than $300. You're up against genuine plastic lips that won't crack or shatter unless you pretty much smash the car. These can be bought 2nd hand (in perfect condition) for $400 (albeit not Series 3 design)...
And it's always hard to advertise one price and then suddenly double that price and not get customer dissention. It's human nature to feel ripped off and decieved.
The way I figured it was I was able to get the Series 3 style lip for $150, and if it cracked.... meh. Not a big deal... But now we're talking $250 for a lip that is quite liable to crack and shatter, it's still a bit harder to justify.
Just a bit of feedback from where I'm standing at the moment.
ph1: The carbon kevlar is again twice as expensive as the carbon fibre.
Merli: Ithankyou for being honest and feed back is nescessary for me to make something that will make your cars stand out and ofcourse add pride to your machine.
Just a short on the durability,
I have noticed that some may not be familiar with the durability of the materials on offer.
Fibre glass: The way in which the glass is layed and the amount of resin used determines flexability. If you request something to be very thick for example 8 to 10 mm thck then the likelyhood of it shatering is much greater. On the otherhand something very thin eg 2 to 4 mm thick is likely to flex alot but may tear so a happy medium between these two is what i try to achieve. If you damage the lip it can be repaired for $50 at most even if its in two bits. then ofcourse painting and re-fitting etc.
Carbon fibre: Is much more flexable and stronger (like 10 fold) in both aspects when applied with the happy medium aplication. but when fixed the repair will stand out like dogs balls because the criss cross pattern will be disturbed unless painted in a colour other than clear. It will still be smooth as a baby's but just the pattern will be disturbed.
Carbon kevlar is very similar to carbon fibre but twice as flexable and strong and also twice the price. It too will look ugly if a repair is needed unless painted in a colour other than clear.
    • I might be way off the mark here.. there must be a T junction under the manifold. That takes manifold pressure through a check valve prior to the T, one side splits out to this bleed off orifice, the other straight to the wastegate actuators.
    • Carrying out some engine due diligence before my first drive in a 260RS that has been in storage for 10+ years, and found two lines that are susposed to be plumbed into the boost control solenoid. One of the lines (the wastegate boost supply line) to actuate the gates, had a bolt in one end blocking it. The other line (main boost signal line) from the very rear of the intake manifold (RB26DETT) and runs up to the boost controller had this pill in the end of it as seen in photos. Other than the obvious (T28 Ceramic turbos might well be cooked)  Can anyone shed any light on if there is any validity at all with this mod, bleeding a constant fixed rate of manifold boost pressure off through this 3mm hole?  Is it deliberate?  Was this a 90s Jap mod done to RB26's? Or has someone just fitted this without any idea of what happens to ceramic T28s if they are not gate controlled?
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
