As always, this is a great build thread. What you have done it what I would love to do..
If you were to put a figure to what you have spent, what would you estimate at? If you don't mind me asking..
Keep up the great work :D
Why wouldn't you use the gtx version?
Because the build started with a turbo I randomly bought... And 3 years ago they weren't really heard of.... And to this day from what I have read I am glad to have a GT over a GTX as they seem to be average at best....
If you had $25,000 you could buy two things, those mods and a cheeseburger :)
Lol they would wanna give you a few grand with that burger....
Boost curve is HEAPS better with the Greddy Profec in comparison to the HKS EVC 5 which is a little surprising.
The car has been run on the dyno since that graph i believe but peak power was bugger all more as the turbo has no more to give, still a big result for a GT30
very good effort that turbo, sure pushing it hard... how are the EGTs? I can imagine you would be able to roast chooks on the exhaust
Yeah thanks mate! I am not sure on the EGT's but with E85 and decent tune i cant see any major issue :)
Nice graph Matt. .
I think you still might be leaning out abit...needs more fuel (kidding :D )
Are you still looking at trying to hit the 400awkw with a bigger snail?
Edited by wedge_r34gtr
I like that dyno printout, been comparing it to mine, 4000rpm is the giggle zone hey .. lol
i think your gt and my gtx are almost identical though, so interesting due to the bad rap the gtx has had, have you thought bout putting a gtx wheel on and shooting for the 400kw?
Edited by AngryRBGTX
Nice graph Matt. .
Nope, ill learn to enjot the car for now, traction is already an issue even with a good setup SO more power is just wank factor (Do want lol) but no point building a car and then putting it into a wall haha
Mmmmm. Thread needs moar 6262.
Great results Mat. Hope you get to enjoy it reliably for a while and have some fun in it at the events.
LOL No it does not, love the 3037 whistle too much :P And yes i hope so too man!
Mine is a little lazy and laggy simply because of the exhaust being restrictive, a setup like this should have more below 4000 and full boost on 3700-3800 BUT i would rather keep it quiet on the street and have that off boost area to keep me out of trouble, but yes beyond 4000 rpm is all skids and lulz
How many tyres do you go through a week? LOL.. I can imagine on song in 2nd she's prancing all over the road
None, i keep breaking stuff lol..... And no prancing!
Except he behaves on the street, don't ya Mat? :laugh:
This man.... He knows!
Keep it to the track! lol
