  • Replies 222
Posted Images
I go online on steam.
Every single person is playing skyrim.
hmmm.
I log onto Xbox Live.
X player is playing Skyrim level X.
I play MW3 by myself. Rage at all the camp/snipe fags after 5 minutes of playing.
I log off.
Well just put about 7hrs into it...
Awesome game. Loved Oblivion, so this is going to get some major play time as its every bit as good.
Just need to really update my PC now and up all settings to max :D
How do you get lost following a road? :D
I started from the wrong place, so I was just wandering aimlessly up the mountain, once I found the right town it was sweet. I also kept finding all these caves that I assumed led you higher up the mountain...they didnt they just spat you back out where you started from after killing a whole bunch of stuff.
Hot tip: theres a spell you can buy early on called 'Clairvoyance'. If you ever get lost it shows you which way to go :)
It was one of the first things I got! However i was doing that wrong too, I had a custom location on my map and clairvoyance was showing me the way there instead of to my objective. I couldnt work out why my Clairvoyance was always taking me the wrong way, but I turned off the custom location marker and now works every time! It is the best spell for me....as I have been getting hopelessly lost in games like this since way back in the Ocarina of time days! lol
    • I said Garrett style. Not Garrett genuine. And something in the G30 550 range is what you want. Not those pokey little old fashioned T28 sized things. The intake ports in the head are small. There is little benefit in fattening up the runners and leaving ths actual ports small. Just run what you've got. And on the subject of Nistune vs Haltech etc..... You know you can control the transmission with decent standalone ECUs these days, right? No need to keep any of that old Nissan bullshit. Don't get me wrong - I use Nistune on my Neo. But it is a DET, so the number of bodges and workarounds I had to do to make it work in a chassis without ABS, TCS, etc, is quite small compared to the herniated arsehole you will have trying to make it work on a motor that doesn't have some of the things that the turbo ECU wants to see. Just easier to bite the bullet and go aftermarket outright.
    • Hmm. Only when the f**king thing is actually working. Still can't find the leak. And that's with dye being put in the last 3 times!
    • Ok so will run the piping over that radiator and no plenum it is. Put that money towards a Haltech and see what suits. Any ideas something like an elite 2000 or 2500 right? My long term goal is 300kw e85 and manual swap and that’s a dream come true. For now will be 200kw and auto the stock rb25det neo intake isn’t too expensive with throttle body. If I was to have the port matching done, Would that be better than the stock de intake as the det has bigger holes plus has the spots for sensors etc? And suit more long term?  appreciate the advice?
    • You understand AFR is not the only thing that contributes to it pinging yeah? Funnily, what the AFR gauge will tell you when it likely is pinging, is going to make you think things are really safe and good.
