  • Replies 482
  • 1 month later...
Selling mine too..... http://www.skylinesaustralia.com/forums/topic/403770-bayside-blue-prime-edition-25t-rs4v-original-car-few-mods/
2000 S2 25T-RS4 V, Prime Edition with all the fruit.
Follow post to car sales advert with lots of pics.
$14,000 137,000 km
Edited by Appealing
Posting to say G'day, moved across from NSW recently with my silver M35.
Enjoying the process of trying to get the car inspected and license changed to WA while having a 9-5 job...
Got an inspection this coming saturday so fingers crossed its all good.
I get the impression there isn't a whole lot of M35's over here...
Cheers
Nick
Failed the inspection on window tint being too dark on the rear windows. One would think if it was able to be complianced and registered in nsw with window tint as is it wouldn't be an issue, obviously not.
Can anyone recommend a decent/cheap window tinter, or somewhere not as an*l.
Thrilled about throwing a hundred bucks away...
Mechanic said 20% on the rear windows. Both driver and passenger windows have already had tint removed which was all the was required for compliance.
Auto power joondalup. Only place I could find open on a Saturday.
Have a bookIng already with a place up in gin gin just in case this happened, but no point throwing another 60 bucks away. So I guess I get the tint removed...
Hey Nick,
If your stagea is anything like mine, the rear windows do not have tint film on them. It's tinted glass (privacy glass in nissans terms) and im pretty sure every m35 came stock with the same, so there isnt even an option to get less tinted glass.
Edited by Ross
look around the edge of the glass. if its tint film u will see that it dose not go all the way to the end of the glass ( crago windows ) if its the rear doors take the trim off and u will see the same at the bottom of the glass
other wise maby try nissan and give the vin number and see if thay can tell if it was form factory
Edited by whitenight27
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
    • Shimmed or shimless, still solid, no hydraulic pump up stuff.
    • They have said food will be limited. Mainly meat pies and sausage rolls from memory. But they have a coffee van!
