  • Replies 743
WOW
this is one crazy build. all the best for this mate. not that you need it seeing as you have top quality shops doing all the work for you but WOW.
also the pic in your sic...do you have high res pic i could use as my desktop please?
For the pic go to downshiftaus.com.au and look for the mercury dyno day blog entry. Navigate to the high res image on flickr.
Re: dashboard, will see which pieces survive the development process, then all pieces will be up for grabs
I have Scott Beeton, a former F1 Aerodynamicist working on the design of the aero pieces.
He is currently busy getting the initial geometry prepared for the baseline GTR CFD simulation.
finally got to meet mark today!
after talking to him for abit, i got to say, he is really enjoy doing this.
u can actually feel the excitement from his tone when he's talking about the things they are going to do to his gtr.
Can't wait to see the end result.
And good luck with the Aero pieces.
*in a vin disel voice* not a bad way to spend $150k!!
You sir have just jumped into one of top ten car builds of all time. cudos to taking such a fantastic base and making it even better! Im sure this will stir many jealous souls. the end result should put this car to the standards or if not higher then the infamous mines vehicles.
cant wait to see the results!
please send my condulances to your wallet...but thank it at the same time!!
There's noise restriction on the track!?:blink:
Those pipe look sexy though.
Unfortunatley yes :(
I have to say this is THE only R35 I like anywhere in the world
It has actual development work done and Mr Handbrake doent have the big head of 99% of R35 owners
:D
Yes unfortunately some tracks have noise restrictions, Lakeside is one of them Eric.
Went there last week with the stock exhaust on because of it.
It's better not to have a big head, less chance of looking stupid when you get things wrong.
:D
Mark certainly doesnt have a big head.
But i would say 99% is an very unfair BS generalisation.
How many R35's in the country? 300? i guess only 3 have their head screwed on right.
The rest of us ae dickheads i suppose.
Edited by LSX-438
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
