  • Replies 743
Manage to catch up reasonably regularly with at least 8 members with R35's on this forum. all top blokes.
Speaking of which Duncan, I am looking forward to catching up at superlap (and any other SAUer's there. as I dont know many of you please come up and say hi).
Unfortunatley yes :(
Yes unfortunately some tracks have noise restrictions, Lakeside is one of them Eric.
Went there last week with the stock exhaust on because of it.
Noise restriction and fast car.... i don't see where this is going...>_<
But Mark, I've listen to the sound of your car once at Mercury, and that just sounds like a machine gun with unlimited rounds of bullets.:worship:
Would love to listen it going through a raceway someday :thumbsup:
silly question regarding the exhaust.
the rear section that has the Tips on it, why does one side have a muffler but no the other? wouldnt htis sound different and flow different? im sure what you have done is right and im just a retard lol but just wondering.
I want to see video of driving it in to Nissan for a "pre track" inspection and saying "it's just got a motec exhaust"
Or demonstrating to Nissan that some mods CAN actually make the car go faster contrary to the line they constantly push that there is no point in modding it....
straight through section for maximum flow, valve shuts it off when I am on tracks with noise restrictions
because of the underbody tray covering the rear section (in its current form) it is a bit of a pain to just swap exhausts so this is the best option
    • Bit of a pity we don't have good images of the back/front of the PCB ~ that said, I found a YT vid of a teardown to replace dicky clock switches, and got enough of a glimpse to realize this PCB is the front-end to a connected to what I'll call PCBA, and as such this is all digital on this PCB..ergo, battery voltage probably doesn't make an appearance here ; that is, I'd expect them to do something on PCBA wrt power conditioning for the adjustment/display/switch PCB.... ....given what's transpired..ie; some permutation of 12vdc on a 5vdc with or without correct polarity...would explain why the zener said "no" and exploded. The transistor Q5 (M33) is likely to be a digital switching transistor...that is, package has builtin bias resistors to ensure it saturates as soon as base threshold voltage is reached (minimal rise/fall time)....and wrt the question 'what else could've fried?' ....well, I know there's an MCU on this board (display, I/O at a guess), and you hope they isolated it from this scenario...I got my crayons out, it looks a bit like this...   ...not a lot to see, or rather, everything you'd like to see disappears down a via to the other side...base drive for the transistor comes from somewhere else, what this transistor is switching is somewhere else...but the zener circuit is exclusive to all this ~ it's providing a set voltage (current limited by the 1K3 resistor R19)...and disappears somewhere else down the via I marked V out ; if the errant voltage 'jumped' the diode in the millisecond before it exploded, whatever that V out via feeds may have seen a spike... ....I'll just imagine that Q5 was switched off at the time, thus no damage should've been done....but whatever that zener feeds has to be checked... HTH
    • I think Fitmit had some, have a look on there (theyre Australian as well)
    • Hah, fair enough! But if you learn with this one you can drive any other OEM manual. No modern luxury features like auto rev-matching or hillstart assist to give you a false sense of confidence. And a heavy car with not that much torque so it stalls easily.
    • Actually, I'd say all three are the automatic option. Just the different trim levels. The manual would be RSFS, no?
