  • Replies 743
thanks guys.
more pics courtesy of Paul Elliot of Elliot Creative Design Co
www.elliotcreative.com
Got to say, that tail wing looks massive!!!!
Also, from the design, it looks like ur using 2 pipe exhaust instead of the normal 4 ones. Any reason y?
Love the images of both race R35 builds in QLD seemingly taking place in sheds, how Australian :)
Maybe the Gov't can use it as an example of what can be built in a shed :P (http://www.mensshed.org)
Hi Eric,
yes the wing is massive but it is CFD tested by Scott Beeton. The plates (we will have spares) will be trimmed and tuned at the track test days. the front canards really arent a true representation of what they will look like as they are quite intricate and indeed also quite large.
the front carbon bumper is down in sydney with the carbon fabricators getting the pieces made and a fair amount of work will be involved in getting the front wings to secure to the car given the levels of downforce applied to them and the larger front splitter.
the exhaust will acually only be a single exit. it is for weight savings and reduced resistance/increased flow
lol, some of mankind's best work has taken place in sheds. though Luke's fabrication shed (one of the three sheds in the mercury complex) now has a lot of very cool toys at his disposal for these kind of jobs
Hi Eric,
Tight fit with the AMS alpha 10 kit
Engine back in
Gearbox and rear end dummy fitted so we can fabricate the custom fuel tank
Rear of car looks very mean!!
AP J hook rotors front and rear
AMS heat sheilds look right at home
ATI damper will help us nudge up the rev limit safely.
Very tight clearances for intercooler piping. We actually had to modify the alpha 10 turbo kit to accomodate the RHD car.
Edited by MercuryMotorsport
ah looks good. Is the carbon fibre dash lighter then the factory one? I haven't been on the inside of a 35 so i have no idea what all the dash is made of. Does look pretty damn cool though.
Considering the extent of the build, the time and expense making a custom carbon dash would be one hell of a waste if it wasn't lighter!
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
