  • Replies 743
is it heavier in the back than the front? is that why you reversed it on the trailer?
It is actually the only way the car will fit!! It is too wide at the front to get onto the trailer. With all of the tools/gear loaded onto the trailer and with the rear mounted gearbox, the trailer is very well balanced in this configuration.
Its very hard to have expectations, but we would like to be sub 1:33's but we have zero experience at EC with this car. I guess that is half the fun! :)
1:33 is seriously quick & in fact quicker than aust superbike class :)
do u plan to take it to wakefield as well?
Being Brisbane based, it is hard to travel interstate to track days, especially as Mark (the owner of the car), is VERY busy professionally and has 3 kids to boot. I think we were lucky to get him out of Brisbane for WTAC!
yeah it's impossible to predict times for a first event of a car. I'm sure they'll just be happy if it runs cleanly and comes back with some good data on where to go from here. it could do a flat 30 or it could be a flat 40.... only one way to find that out. :)
I would pay good money for it to do a flat 30! Might be necking myself if it does a flat 40!!! :P
Below is the results from last year so will be interesting to say the least. There were some big names in the 1:35 plus area so only time will tell.
1 Tarzan Yamada- CyberEVO- Mitsubishi EVO- 1:30.5870*
2 David Empringham- Sierra Sierra- Mitsubishi EVO- 1:31.8840 +0:01.2970
3 Tarzan Yamada- Tomei/Cusco- Subaru Impreza WRX- 1:31.9010 +0:01.3140
4 Warren Luff- Prep'd Motorsport- Lotus Elise- 1:32.2730 +0:01.6860
5 K Sasaki- Pan Speed Racing- Mazda RX-7- 1:32.4540 +0:01.8670
6 Kinoshita Mitsuhiro- Pro Staff R-Magic- Mazda RX-7- 1:33.5050 +0:02.9180
7 Mark Berry- Advan/Hi Octane Racing- Nissan Skyline R34 G- 1:34.1090 +0:03.5220
8 David Loftus- BSM Motorsport- Nissan Skyline R32 G- 1:35.8760 +0:05.2890
9 Garth Walden- Tilton Interiors- Mitsubishi EVO- 1:37.0590 +0:06.4720
10 Peter Lucas- Kirrapak Racing- Lotus Elise HPE- 1:37.4240 +0:06.8370
11 Russell Newman- Advan/Hi Octane Racing- Nissan Skyline R32 G- 1:38.2190 +0:07.6320
12 Mal Rose- Mal Rose Racing- Holden Commodore- 1:39.3230 +0:08.7360
13 Jose Fernandez- Fernandez Motorsport- Ford Falcon- 1:40.2170 +0:09.6300
14 Cameron Dyal- APC Racing- Mitsubishi EVO- 1:42.7990 +0:12.2120
15 David Hommer- 999 Automotive- Honda Integra Type R- 1:46.0140 +0:15.4270
Cheers
Marty
i have been told when loading a car onto a trailer not to put it backwards.
due to 80% of the weight being behind the axle.
other than that epic, and i cant wait to make the trip over there tomorrow!!
R35 is a bit different to most cars. particularly a track R35. don't forget they have a transaxle so lots of weight in the rear and consequently less weight up front. and don't forget they balanced it further with tools etc. but the point is if the car only fits backwards, you put it on backwards.. I don't think driving it to sydney was an option...
Cheers
Marty
agreed. I reckon if they break a 35 for their first big event that will be a massive achievement. anything past that is gravy. hell under a 40 is a big effort.
Given both cars (R35's) are basically just built and untested if they can beat the High Octane R32 they will be doing very very well IMO.
Both these cars are amazing bits of gear - but I think they will still need a few more miles under their belts - and a bit more tweaking - before their true potential can be realized. I don't think bolting them together and just doing 1-2 days testing will quite get them there yet.
But anything under a 1.40 will be a really great effort.
No doubt this year will be a massive learning year for them both - and look out seriously for them in 2012.
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
