  • Replies 112
Oh and wreckedhead, 11.6 @ 120mph is a good time but consider the following:
BU5TER: 2.5l, TD-06 25G, RWD
JETT aka 'nicknick': 2.6l, T78-33D, AWD AND C16 Fuel !!!!!
:D
Oh and BU5TER went 11.7 @ 128mph with a 2.0 60ft .... When he runs 1.7 60' just you wait and see what happens...
Adrian
Thanks guys.  These std turbos work great, I dunno why everyone changes them for bigger ones?!?!?!
Adrian
Well done Adrian, nice work mate.
Indeed the standard turbo does work great, mind you when you add nitrous you'd expect it too. Hmmm... maybe I should get myself a 50hp kit too.
What's the bottle cost to fill, and how many passes per bottle?
So do you run it on the street? C'mon tell the truth now :)
The ONLY down side I can see in having gas (rather than a bigger turbo etc...) is you don't get to use the power whenever you want to. Say on a cruise in the hills, a full track day, the traffic light grand prix, and that sort of thing. I guess if you have a huge nitrous bottle it wouldn't be a problem. The legality issue isn't as much of a concern as what ISN'T illegal these days.
A bigger turbo AND gas is the best way to go.
Hmmm... cams or nitrous?
How quick is your car without the gas?
10lb (D Size) bottle = $100.00 = 100hp for 100sec
No.
13.471 @ 104.56mph - (2.2 60')
Adrian
No.
Adrian
Thanks for answering my constant questions Adrian :D
So do you know what rwkw gain your car makes on the gas (before/after fig's) ?
By the looks of things it makes a massive difference! An 11mph gain in TS is excellent.
$100 isn't bad at all, considering the number of passes that gives you. $1 per second doesn't sound as good though :)
It'll be very interesting to see how much quicker you'll go with a 100hp shot. With good traction the low 12's / high 11's (@ 120mph) may well be possible!
Cheers,
Matt
Holy shit i'd better not go out in public again the shame of a T78 powered GTR beating me by one 10th and at 120mph hahahaha is to much to take  :devfu:
dont worry my cars already having the twin plate clutch put in so next week hopefully it wont slip of the line and in third gear, but thats ok im not asshamed at 11.6, its not a bad time considering i only spent about a grand on the car since i bought it.
    • What are we supposed to be seeing in the photo of the steering angle sensor? The outer housing doesn't turn, right? All the action is on the inside. The real test here is whether or not your car has had the steering put back together by a butcher. When the steering is centred (and we're not caring about the wheel too much here, we're talking about the front wheels, parallel, facing front) then you should have an absolutely even number of turns from centre to left lock and centre to right lock. If there is any difference at all then perhaps the thing has been put back together wrongly, either the steering wheel put on one spline (or more!) off, and the alignment bodged to straighteb the wheel, or the opposite where something silly was done underneath and the wheel put back on crooked to compensate. Nut there isn't actually much evidence that you have such a problem anyway. It is something you can easily measure and test for to find out though. My money is still on the HICAS CU not driving the PS solenoid with the proper PWM signal required to lighten the load at lower speed. If it were me, I would be putting either a multimeter or oscilloscope onto the solenoid terminals and taking it for a drive, looking for the voltage to change. The PWM signal is 0v, 12V, 0V, 12v with ...obviously...modulated pulse width. You should see that as an average voltage somewhere between 0V and 12V, and it should vary with speed. An handheld oscilloscope would be the better tool for this, because they are definitely good enough but there's no telling if any cheap shit multimeter that people have lying around are good enough. You can also directly interfere with the solenoid. If you wire up a little voltage divider with variable resistor on it, and hook the PS solenoid direct to 12V through that, you can manually adjust the voltage to the solenoid and you should be able to make it go ligheter and heavier. If you cannot, then the problem is either the solenoid itself dead, or your description of the steering being "tight" (which I have just been assuming you mean "heavy") could be that you have a mechanical problem in the steering and there is heaps of resistance to movement.
    • Little update  I have shimmed the solenoid on the rack today following Keep it Reets video on YouTube. However my steering is still tight. I have this showing on Nisscan, my steering angle sensor was the closest to 0 degrees (I could get it to 0 degrees by small little tweaks, but the angle was way off centre? I can't figure this out for the life of me. I get no faults through Nisscan.
    • The BES920 is like the Toyota Camrys of coffee machines. E61 group head is cool, however the time requirements for home use makes it less desirable. The Toyota Camry coffee machine runs twin boilers and also PID temp control, some say it produces coffees as good as an E61 group head machine.
    • And yes with a full tank it will hit limiter free revving or driving 6B6CDF6E-4094-426D-A9CB-6C553475FE36.mp4
    • One way of putting the fuel surge idea to rest, is that even when in neutral/clutch in or free revving it still has the same issue, it can’t even get to limiter (7800) so to me that says it can’t be g force, I’m not trying to argue I just want to find the f&$king issue 😡
