lol, well fair enough steve-o and paul, I still say you guys are lazy. shit even F1 teams use gravity to put their fuel in!!! but you guys need pumps? maybe an easy idea would be a simple gerry can stand? hold the can at the correct height, would flow a hell of a lot faster than a pump rig... would be hands free once you lift the can up, and let the good times flow....
still each to their own. i need the exercise I get from occasionally lifting up a 20kg can and holding it for 30 seconds or so. :)
LOL. It came in handy this week. Draining fuel from a car which you couldn't turn the engine on. Through the boot and suck away. We got a multi on it.... 10.5 V at the pump terminals. Hmmm. Shorter cables with a possiblilty of doubling them up or a thicker cable with a 12 V rated switch, not a 240V. V 2.0 in progress ;)
I thought about a stand before this, but all the stands that I was thinking about had the same problem of being too big when packed away in the car when driving somewhere but the fuel pump is just that, a pump and some lines all of which easily fit into one of those enviro bags you get from coles :)
Time to shorten the wires, get slightly larger ID tubing and then finally mount it so it doesnt look to pov spec
paul has guns to hold 100kg of e85 - stevo on the other hand...hmmm
HA!
beerbaron - u cracked me up with your comment of f1 teams using gravity fed jerry cans, very true & very funny
lol, i'm reading that marko thinks he can take steve-o in a bout of greco roman wrestling... happy to referee if needed...
just don't fart when you are locked in some kind of gay choker hold. it's not polite and will get you disqualified. and no john hoppa type finger pointing pls.
this is what I envisage. marko v steve-o. who can tell where one man ends and the other begins? beautiful it's own disturbing way...
hi nathan - house reno's is taking up too much of my time, im always thinking about this damn pump though & very keen to see how it performs.
the good news is that i did sell my old surge which had 2 x 044's & also sold my intank 044.
i also need to determine what pump is currently running intank in my gtr - i should just ask my mate who had this mod done 15yrs ago (i think its a nismo)
  • 5 months later...
Back from the Dead..
what in tank pump would be best to use on a R33 300-400rwkw running E85
Aeromotive 340 Stealth inline and deatschwerks pump look the goods but would they keep up for a car on E85 say 350Kw and boost max of 25Psi?
They look like they can for 98 but will the flow be enough for E85?
(currently have a Walbro 255 HP? which i don't think will cut it.. could i be wrong?)
  • 1 month later...
i believe the Aeromotive 340 pumps dont like E85 ...i have heard of a few failures of them when using e85, shame because when i saw them i was hoping i could use them also.
Looks like 044 wins again.
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
